Something weird in my coolant over flow bottle
Old Oct 9, 2008 | 05:38 PM
Dynosty's Avatar
Dynosty
Vendor - Former Vendor
Originally Posted by chris'smax
Also i can see no signs of fluid runing down the block from the heads.
Most of the time you won't. It is more likely to see coolant in the oil, oil in the coolant, air in the coolant, smoke in the exhaust, low compression... but now fluid running down the block from the heads. What coolant are you using?
Old Oct 9, 2008 | 06:06 PM
Barzten1's Avatar
Barzten1
Nothing ever came of it. It actually disappeared. I run 50/50 water coolant. I have a Koyo radiator but Im not sure which one. I had it with the Vortech kit so Im thinking it might be the slimmer one. How can I find out which radiator I have?
Old Oct 9, 2008 | 06:32 PM
Quamen's Avatar
Quamen
This sounds dumb but I have seen Barsleak leave that residue. Has the radiator or block/heads ever been used with that stuff? I used it on a car once for a simple leak from a radiator a couple days before a race because we couldn't get it fixed and then flushed the system after getting the radiator fixed. I still continued to find it for a long time after though.
Old Oct 9, 2008 | 06:57 PM
350 Rookie's Avatar
350 Rookie
I am going to open the rad cap when the car cools off smart ***. I Don't feel like getting burned.
BTW aren't you the guy that JUST ****ed up your built block by putting old plugs in a new motor?
ya thats why rad caps have 2 steps. one to releive pressure and one to take off.
and ya you're right, it was definitley caused by the plug.
Old Oct 9, 2008 | 08:13 PM
SpoilsofWar's Avatar
SpoilsofWar
The "official" nissan RTV is an orange color. Just a thought, maybe it was applied a little heavy at, say the rear coolant crossover pipe flanges, and squeezed into the coolant passage.
Old Oct 9, 2008 | 08:58 PM
thawk408's Avatar
thawk408
The official nissan RTV is gray last I remember. Orange indicated the high temp RTV, which nissan doesnt use.
Old Oct 9, 2008 | 10:35 PM
chris'smax's Avatar
chris'smax
Originally Posted by rcdash
Are you running pure water or 50/50? (have you ever run just distilled water)
i think it is running just 50/50 from the looks of it.
Old Oct 10, 2008 | 08:29 AM
ADMAN's Avatar
ADMAN
Distilled water + Water Wetter =
Old Oct 10, 2008 | 10:29 AM
350 Rookie's Avatar
350 Rookie
nope, orange
Old Oct 10, 2008 | 11:27 AM
BriGuyMax's Avatar
BriGuyMax
Turbo Whore
The RTV that comes with a Nissan factory engine rebuild kit (gaskets, ect.) is orange. The FACTORY RTV is gray. I have a tube of orange nissan gasket maker sitting in my garage from my build.
Old Oct 10, 2008 | 12:18 PM
chris'smax's Avatar
chris'smax
the question is how did that $hit make its way into my coolant bottle?? lol
Was it just excesss RTV that was in the coolant passages?
Old Oct 10, 2008 | 12:58 PM
str8dum1's Avatar
str8dum1
r u sure its rtv? it's rubbery?
Old Oct 10, 2008 | 01:03 PM
Jay'Z's Avatar
Jay'Z
Hopefully excess......
QuadCam's Avatar
QuadCam
I just so happen to look in my coolant overflow bottle and i noticed some orange looking substance floating in the bottom of the bottle. I dont remember seeing it the other day when i looked. Has anyone ever seen anything like this? It looks almost like some kind of algae?
I have some wierd flaky **** in my overflow canister too. I was worried about it, but then I have had my oil analyzed 3-4 times since I first noticed it. I have had ZERO coolant in my oil analyses...so, I suppose the opposite is also true. I wouldn't worry about it.
Old Oct 10, 2008 | 01:32 PM
thawk408's Avatar
thawk408
I didnt get any rtv in my rebuild kit, so that would explain why I havent seen the orange used.
The factory rtv that the engine comes with off the assembly line is still gray. Unless they just wanted to use gray on mine.
Old Oct 10, 2008 | 01:52 PM
JAM3Z's Avatar
JAM3Z
Phenom
I'll be damned if I didn't look into my coolant tank today and see the EXACT same thing. Weird.
Old Oct 10, 2008 | 02:55 PM
chris'smax's Avatar
chris'smax
ahahhaha. So someone ate doritos and spit in your tank also??
Old Oct 10, 2008 | 04:09 PM
  #38
SpoilsofWar
Correct, my rebuild kit came with the orange Nissan stuff.
sorry for the confusion.
Old Oct 10, 2008 | 05:01 PM
  #39
BriGuyMax's Avatar
BriGuyMax
Turbo Whore
Not really sure...all gaskets involved with the cooling system are rubber or metal IIRC. It could have just been a little rust. Which is no big deal. Unless you see a lot of it and your coolant gets cloudy, I wouldn't worry about it all.
Old Oct 11, 2008 | 01:47 PM
  #40
Q45tech's Avatar
Q45tech
Where would rust come from? Rust requires Iron to make the iron oxide. What part of coolant exposed system is made from anything but aluminum alloys?
High School Chemistry
