Supercharger for my 350Z?
Old Nov 17, 2008 | 01:26 PM
Remix919's Avatar
Remix919
Default Supercharger for my 350Z?
Hey there, I was wondering if anyone knows of a supercharger being sold for the 350z? I looked up new ones and they all cost from $3800 and up. I'm not rich, so I'm not looking for the best ever supercharger, and I'm perfectly fine with a pre-owned one that's in good condition. I'm looking to hopefully spend around $2000. The only real requirement I have is that I don't want to have to do any additional mods to the car such as high performance pulley's or anything like that. Any advice/help would be greatly appreciated I'm looking to use my x-mas money to purchase.
Old Nov 17, 2008 | 01:29 PM
AroundMyHorn's Avatar
AroundMyHorn
Use the search tool kiddo, there is plenty of info on this site.
With that said, you need to save more money.
Old Nov 17, 2008 | 01:30 PM
Done Deal DR's Avatar
Done Deal DR
Hmmm good luck.
Your ONLY shot is to scour the marketplace on here and Ebay for a used supercharger setup. Unfortunately even those are out of your budget from almost everything I've seen being sold. You also take the risk of a damaged unit or missing parts, however there are always superchargers being sold as a lot of the people buying them aren't happy with their power levels and switch to a turbo setup later on.
Old Nov 17, 2008 | 01:33 PM
Z You Later's Avatar
Z You Later
this is my one pet peave of mine is to try to budget in a FI system...what you REALLY need to consider is that there will be maintenance and problems may occur...both are not cheap...
plus with that much power you're going to need bigger wheels, better tires, a big brake system to stop the extra power, a ECU management system...
with this said your goal of $2k for a supercharger will most likely not happen BUT if you find all you need for the price and it's not broken then great for you
Old Nov 17, 2008 | 01:35 PM
cdoxp800's Avatar
cdoxp800
Revup or Non-Revup??
https://my350z.com/forum/turbos-nitr...g35-coupe.html
Old Nov 17, 2008 | 01:38 PM
enuff4life's Avatar
enuff4life
get NOS for $2000
Old Nov 17, 2008 | 01:44 PM
Remix919's Avatar
Remix919
I already checked the classifieds, but nothing there that was in my price range, I found a turbo setup there for $2500, but it was sold already
yogipower's Avatar
yogipower
not again...
Old Nov 17, 2008 | 01:45 PM
Remix919's Avatar
Remix919
Originally Posted by cdoxp800
I'm not too familiar with the car yet, just got it, how can I tell which one it is?
Old Nov 17, 2008 | 01:49 PM
Remix919's Avatar
Remix919
Ok, so it seems my expectation to get a small supercharger or turbo setup for around $2000 isn't going to work out, but could you guys give me some pointers on what price range I should be looking at? I don't want anything crazy, just some more high end power.
Old Nov 17, 2008 | 02:18 PM
Z You Later
for your money get a NOS system...but for a good setup that won't technically break the bank look to spend at least $5 if done correctly...or give or take a few hundred at $4 for a used setup
Old Nov 17, 2008 | 02:23 PM
raf84ny's Avatar
raf84ny
I would say, save up the money and spend alot of time here on the forum to due your research. There's alot of info out there.
Old Nov 17, 2008 | 03:13 PM
Vas@Extended's Avatar
Vas@Extended
Vendor - Former Vendor
you got lots to learn... save your money though... boosting a Z isnt going to be cheap
Old Nov 17, 2008 | 03:23 PM
MDK's Avatar
MDK
As many people have said, you're going to need a LOT more money for supporting mods, if you want to do it right.
I bought my supercharger setup for about $3500, and I've got easily double that in the ecu, injectors, fuel pump, gauges, etc that support the supercharger.
Old Nov 17, 2008 | 03:37 PM
TinmansZ's Avatar
TinmansZ
Listen to the advice of those who have gone before you, you can't FI for cheap. Believe me, I've spent more in mods then I paid for my car new. Once you start you can't stop. I'd say spend your 2 g's on some NA mods like exhaust, spacer, hi flow cats exc. Then someday if you get a SC these mods will only help you. Good luck.
Old Nov 17, 2008 | 06:15 PM
Car vs. Driver's Avatar
Car vs. Driver
No way you'll do it for 2K ... just no way. If you want to do something, do it right the first time. Cheaping out will only cause you more headache and money in the end.
Old Nov 17, 2008 | 06:20 PM
got556's Avatar
got556
I'm just gonna say to be ready to have $10K set aside for the plan...and that's not building up the motor. You wanna build up the motor...add another $10K....and that's whether you turbo or SC...plus don't forget clutch/flywheel and axles....
It adds up quick and I haven't even pulled the trigger yet.
Old Nov 17, 2008 | 06:28 PM
TSG-Z's Avatar
TSG-Z
What year is your car? PM me were both in NC, maybe I can help you up your knowledge before creating such noob-like threads!
Old Nov 17, 2008 | 08:51 PM
350Z400rwhp's Avatar
350Z400rwhp
Rule of thumb with FI.....Take what you are initially thinking of spending and triple it lol If you have 2k to spend either save it and do research on here for a few months or buy all the supporting mods you are going to want like a, manifold spacer, exhaust, Utec, fuel pump, injectors, down pipes.......
Old Nov 18, 2008 | 05:36 AM
2004Black350z's Avatar
2004Black350z
Exhaust Whore
+1
