SHAFT PLAY!?
Old Dec 9, 2008 | 05:18 PM
bbs350z's Avatar
bbs350z
Default SHAFT PLAY!?
and not in a sexual sense either
traded my 18g's + cash to another member on here for a set of 60-1's rebuilt by forced performance, with 1800miles on them i was told. i was checking them out last night, and i noticed the turbo wheel wiggles slightly from side to side, but doesnt come into contact with the turbo housing whatsoever. im doing a high hp build and while i know a little shaft play is acceptable, how much i unacceptable? how bad would it hurt performance? should i opt for a rebuild? get my old stuff back? help me out guys im bummin
Old Dec 9, 2008 | 05:22 PM
Nexx's Avatar
Nexx
ahh.. i was about to say, im all for shaft play.
Old Dec 9, 2008 | 05:52 PM
RED RIDER's Avatar
RED RIDER
I've always understood that a few mm side to side is okay..up and down play is bad news..cheer up..they should be fine..
Old Dec 9, 2008 | 06:00 PM
Chef-J's Avatar
Chef-J
Booooosstt!!
Sorry to hear. If you are not happy with it then get yours back.
Hope everything works out.
Old Dec 9, 2008 | 07:07 PM
350 Rookie's Avatar
350 Rookie
i think under .050" play is acceptable. Check with a dial indicator and see what you got.
Old Dec 9, 2008 | 07:53 PM
BoostedProbe's Avatar
BoostedProbe
I recently bought a brand new Garrett 60-1, and when I recieved it I wanted to see how much play a new turbo has. I was actually suprised at how much sideways play there is, but it's brand new from a reputable dealer so it has to be ok. I'v never had a turbo in my hands so it's all new to me, but from what I have read side play is ok. If it has vertical play then that is a big problem.
Old Dec 10, 2008 | 11:04 AM
bbs350z's Avatar
bbs350z
i played with my friends gt30r and there is absolutley no play whatsoever. i'll check with an indicator rook, and see what comes out. btw nexx, how you liking the tails?
Old Dec 10, 2008 | 11:06 AM
Jarred@Z1's Avatar
Jarred@Z1
Z1 Motorsports
a small amount of play is normal especially in ball bearing turbos.
Old Dec 10, 2008 | 12:51 PM
tylerxfire's Avatar
tylerxfire
good info here then, my turbo must be fine, im guessing maybe a millimeter of play side to side and nothing up and down i have when i checked it out
Old Dec 10, 2008 | 04:44 PM
Sharif@Forged's Avatar
Sharif@Forged
Forged Performance
Based on your description, the shaft play is fine. Shaft play is usually within spec, or the wheel is done and wobling all over the place. Not really much middle ground.
Old Dec 10, 2008 | 04:50 PM
tig488's Avatar
tig488
just make sure the wheel doesnt contact the housing! some play is fine, once oil fills the cartridge it doesnt move as much.
Old Dec 10, 2008 | 04:53 PM
Jarred@Z1's Avatar
Jarred@Z1
Z1 Motorsports
^yarp, the oil pressure does the supporting.
Old Dec 10, 2008 | 04:54 PM
tylerxfire's Avatar
tylerxfire
well this gave me confidence my turbo is good. . hope it helps everyone else, thanks.
Old Dec 10, 2008 | 08:05 PM
thawk408's Avatar
thawk408
Its fine. Boost away.
Old Dec 10, 2008 | 08:07 PM
SnyperZ's Avatar
SnyperZ
hell no..thats ALOT of play..there isnt even that much space between the housing and the wheel.
Old Dec 10, 2008 | 09:15 PM
iamdigital's Avatar
iamdigital
I noticed the same thing about the 60-1s when I bought a kit from a guy. I was told the same thing. BB turbo has a lil shaft play side to side but should be far from touching sides.
Old Dec 12, 2008 | 12:56 PM
bbs350z's Avatar
bbs350z
yea i was thinking once oil got in itd kill some of the play. thanks guys, got my hopes back up!
Old Dec 12, 2008 | 01:33 PM
urbancamoM7's Avatar
urbancamoM7
hope it turns out good man. let us know how the build goes.
aarrgghh
May 1, 2022 11:04 AM
bcoffee20
Nov 19, 2015 06:39 PM
Depravity
Oct 1, 2015 04:49 PM
TrackFiddy
Sep 24, 2015 09:36 AM
