Greddy Turbo Rebuild
Old Jan 5, 2009 | 11:01 PM
ttg35fort's Avatar
ttg35fort
Professional
Originally Posted by JETPILOT
This might make me sell the car. I don't want to deal with this anymore.
No. Don't sell. Pleeeeaaasssseeee
Too many of the top ballers and dropping out. Not you too...
Get them re-built, or buy some used ones off a pansy that dropped out.
Old Jan 5, 2009 | 11:34 PM
JETPILOT's Avatar
JETPILOT
Every time I think I have chased away all the demons something else pops up. I've devoted too much time and money to this. I can't afford to pay over $1000 for a track day and only have the car make it 1/4 way through it.
I need to solve the crankcase pressure issue and the turbo's won't leak anymore.
Old Jan 6, 2009 | 12:35 AM
tecni's Avatar
tecni
turbochargers.com or redatt of north america.
Old Jan 6, 2009 | 05:12 AM
str8dum1's Avatar
str8dum1
a hundred dollar chevy S10 vacuum pump, and a boost switch will solve your problems as well.
are sure your oil pressure to the turbos is not too hi?
Old Jan 6, 2009 | 06:13 AM
RED RIDER's Avatar
RED RIDER
That sucks bro..bummer..ironically enough my Z is setup very close to what you had suggested, the only difference being that the drivers side is not "drilled out". I still have the freaking coolant pressurization issue and just picked up a "combustion gas in the coolant tester". I think I will try another new greddy or toyo high pressure cap, buy a nismo low temp thermo and see what it does then. I can cruise around all day long not going into boost and have no issues, if I beat on it then the overflow fills up and the car will eventually overheat because of an "airlock" situation. I've been ready to pull my hair out with this crap..but take a deep breath and keep working the issue. Think how good its going to feel when you get the issue resolved and you can run the crap out of it at the track! You're on the leading edge of this with as much HP as you're making..so don't give up..stay after it!
Old Jan 6, 2009 | 02:44 PM
str8dum1's Avatar
str8dum1
^^if the tank is overflowing, sure you dont have a blown headgasket?
Old Jan 7, 2009 | 04:09 PM
rrmedicx's Avatar
rrmedicx
The only reputable choice is Forced Performance. IMHO.
Old Jan 7, 2009 | 04:11 PM
JETPILOT's Avatar
JETPILOT
I have not checked the oil pressure to the turbo's. I am running the Forged Performance upgraded oil ines. How would I check the oil pressure at the turbo?
Old Jan 7, 2009 | 07:57 PM
350 Rookie's Avatar
350 Rookie
I dont know why forced performance sounds so funny. lol
Old Jun 23, 2009 | 10:12 AM
IslandZavage's Avatar
IslandZavage
i just went to the site for Forced Perfomance..says there out of Texas, but a earlier post says florida.. need to get mine rebuilt possibly
Old Jun 24, 2009 | 06:26 AM
Cass007's Avatar
Cass007
You can try:
http://www.blouchturbo.com/upgrades/
At least you can compare costs this way. BTW, the turn time on my upgrade was amazing. Good luck.
Old Jun 24, 2009 | 08:01 AM
rocks's Avatar
rocks
Run valve cover breather vents into your exhaust after the turbo. See it at the drag strip all the time with high compression v8s. The exhaust will keep it in someone what of a vacum. You need to take a small pipe and angle it into the exhaust pipe, facing the rear of the car, at an angle. This way the exhaust will draw pressure out of the crank case.
Link with pictures to give you an idea.
http://www.teglerizer.com/triumphstu...scavenging.htm
Jegs has the kit you need.
http://www.jegs.com/i/Moroso/710/25900/10002/-1 60$
350Z_Al
Oct 29, 2020 07:44 PM
sales@czp
Sep 23, 2019 03:30 PM
