Egt question
Old Jan 9, 2009 | 12:44 PM
nomyth46's Avatar
nomyth46
Default Egt question
i have a greddy TT kit and i was just wondering what kind of EGT's were some of you running?...........at WOT and just cruising
Old Jan 9, 2009 | 09:57 PM
terrycs's Avatar
terrycs
Maybe up to 1400 deg F on the high side / 1200 deg F at cruise / down to 750 deg F at idle. HR motor with sensor located in the exhaust manifold.
Old Jan 10, 2009 | 03:49 AM
nomyth46's Avatar
nomyth46
what kind of kit are you running?
Old Jan 10, 2009 | 11:23 PM
terrycs's Avatar
terrycs
GTM, but it shouldn't be much difference if you have an HR motor as well:
https://my350z.com/forum/shop-builds...ock-block.html
Old Jan 11, 2009 | 06:36 AM
craigo'sznprgrs's Avatar
craigo'sznprgrs
WOT usually 1150-1200 never seen it over 1250
Crusing around 900 at 80 mph
Old Jan 11, 2009 | 08:39 AM
350 Rookie's Avatar
350 Rookie
1400?!?!?! I dont think its supposed to be that high.
Old Jan 11, 2009 | 09:04 AM
thom000001's Avatar
thom000001
EGT's are tough to compare.
Placement of the probe means sooooo much. a 1 inch difference in placement can mean 100degrees difference.
djtimodj's Avatar
djtimodj
Guys I'm looking into fitting a defi EGT set up in my car when I get my APS TT fitted. Where the best location for the sensor? Pre cat or after the cat and I'm not sure what bank to put it in? Could I fit it into the outlet of my Y pipe or is this to far from the block and would read low?
Old Jan 11, 2009 | 09:29 AM
XKR's Avatar
XKR
And what wrong with 1400 At WOT thats about what mine is at.
That is so true
Old Jan 11, 2009 | 09:34 AM
thom000001's Avatar
thom000001
Thats waaaaaaayyyyyy too far away. Pre-cat may never break 800 degrees post cat you'd be licky to be over 600 degrees (just guessing on those numbers but they'd be waaay lower than in the manifold).
Also you'd really want 2 (one for each bank). In a perfect world you'd want 6, one in each runner of the manifold.
Idealy you want it in the manifold.
Old Jan 11, 2009 | 12:35 PM
nomyth46's Avatar
nomyth46
i have 2 probes one on each manifold right next to the head
Old Jan 11, 2009 | 12:36 PM
nomyth46's Avatar
nomyth46
XKR what kind of setup are you running?
Old Jan 11, 2009 | 12:37 PM
nomyth46's Avatar
nomyth46
my EGT's run about 1400 to 1450ish under WOT..........it stays around 1100 cruisin
Old Jan 11, 2009 | 03:28 PM
XKR's Avatar
XKR
I have the Defi.....and they are located halfway down my 3.5" APS down pipe.
Old Jan 12, 2009 | 06:36 AM
coachk's Avatar
coachk
I will PM you some pics of my EGT sensor location. I have the APS TT and defi gauge.
Cruising at 80mph mines @ 1000F on a built motor.
Old Jan 12, 2009 | 08:33 AM
djtimodj's Avatar
djtimodj
Thanks alot mate. Im leaning towards going for the sensor in the 3.5 inch down pipe as i can fit the senson bung and get it welded in before they go on the car.
Old Feb 12, 2009 | 12:04 PM
ashtrojan2008's Avatar
ashtrojan2008
definitely go in the exhaust manifold, where all the ports come together. After the turbo will be at least 300 degrees cooler since the turbo is oil cooled.
Old Feb 12, 2009 | 03:52 PM
QuadCam's Avatar
QuadCam
to really know what is going on...you'll want the sensor between the head and the turbo. you want to know the highest EGTs!!!
issyz
Jul 2, 2017 03:04 PM
Alexreyes
Sep 30, 2015 11:30 PM
Conway_160
Drag
Sep 29, 2015 08:07 AM
