Weird power steering issue (power steering randomly going out)
Old Jan 18, 2009 | 03:45 PM
chris'smax's Avatar
chris'smax
Default Weird power steering issue (power steering randomly going out)
After washing my car today at a car wash i started to leave when all of a sudden i noticed my power steering wasn't working. I got the car home and noticed that the power steering fluid level was a little high so i removed some of the fluid. After doing this i took the car for a spin around the neighborhood and everything was fine. I have had this happen a couple of times before where the power steering just randomly goes out. i am wondering if there is a possibility that the power steering pump maybe has air in the system and is cavatating. Is this possible?
Has anyone else had this problem?
Old Jan 18, 2009 | 05:23 PM
plumpzz's Avatar
plumpzz
Perhaps it boiled over and a bubble isnt escaping your system? Maybe thats why the level seemed high for no reason. This happened on my parents 2001 xterra. It was fixed with a new pump (old car..) and new fluid in the system.
Old Jan 18, 2009 | 05:34 PM
chris'smax's Avatar
chris'smax
could be.
The last time it happened i added a little fluid and let it sit for a few mins and it was fine. Like i said this problem occurs out of the blue.
I don't think it is heat related from the turbos becuase every time it has happened the car has been driven under low load.
Old Jan 19, 2009 | 01:01 AM
leeboyNY's Avatar
leeboyNY
Kimchi Eater
I agree. It happened to me as well. Even without our turbo system, our power steering oil boils very easily.. Try some heat shielding and maybe upgrade your power steering oil cooler.
Old Jan 19, 2009 | 04:12 AM
chris'smax's Avatar
chris'smax
can you explain your experience and how you resolved it?
Old Jan 19, 2009 | 04:53 AM
blasian's Avatar
blasian
It could be because you didn't go to the track Saturday
Old Jan 19, 2009 | 08:21 AM
chris'smax's Avatar
chris'smax
didn't have time to change to change my oil saturday sucka.
This 1500 mile oil change interval is owning my *** lol.
Old Jan 19, 2009 | 08:50 AM
BlinkerFluid's Avatar
BlinkerFluid
Did you possibly get the belt wet?
That could cause it to slip a bit and not work properly.
Old Jan 19, 2009 | 09:47 AM
blasian's Avatar
blasian
You're such a n00b
Jason and I could change that chit in a matter of seconds.
Old Jan 19, 2009 | 09:55 AM
chris'smax's Avatar
chris'smax
You're such a n00b
Bah not when your intercooler pipes have the oil filter caged in lol!
Its so sad i have to remove my pipes to take the ****ing oil filter off.
Old Jan 19, 2009 | 09:58 AM
blasian's Avatar
blasian
Go to the 5 Minute Oil change place, I just want to see their reaction
Old Mar 3, 2009 | 06:15 AM
chris'smax's Avatar
chris'smax
any more input guys? This **** is weird. It will happen after a couple of mins of driving (sometimes) and i can shut the car off then immediately turn it back on and the steering is fine.
Old Mar 3, 2009 | 07:00 AM
blasian's Avatar
blasian
You need an upgraded power steering chip.
Old Mar 3, 2009 | 07:03 AM
Glex25's Avatar
Glex25
sounds like the power steering pump.
I had that after a night of doing donuts and the dealer replaced
it under warranty but mine was more severe.
Old Mar 3, 2009 | 07:04 AM
Jason333's Avatar
Jason333
hi
When it does it do you hear any noise at all from the engine compartment? Power stearing whine etc?
Old Mar 3, 2009 | 07:08 AM
blasian's Avatar
blasian
Yeah, didn't you have an issue with your ps overheating?
Old Mar 3, 2009 | 08:59 AM
chris'smax's Avatar
chris'smax
yea the pump still whines.
I am wondering if maybe some debris is in the pump or maybe a air pocket?
Old Mar 3, 2009 | 09:01 AM
blasian's Avatar
blasian
Day gathering to fix it
Old Mar 3, 2009 | 10:24 AM
j.arnaldo's Avatar
j.arnaldo
Don't wait till it makes you get a workout (i.e. allowing it to go out completely); visit your nearest power steering repair shop.
Old Mar 3, 2009 | 03:45 PM
superchargedg's Avatar
superchargedg
Damn Noobs
If it is making a whining sound it has air in the system and it needs to bled out.Start by having the engine off and turning the steering wheel back and forth multible times.Watch the ps fluid resivour and see if bubbles are present....if they are keep turning the wheel back and forth(your arms will feel like fireballs at this time)untill you see no bubbles.
Once you see no bubbles start the car up and fill the resivour as needed.I had to help Alberto with this same problem and we fixed it.
