XKR Super G... Going for Mach 1
Old Dec 7, 2009 | 09:37 PM
  #2281
XKR's Avatar
XKR
I am installing a traction control.... With it installed...I could floor it at high boost and still have full control. I have another car with the same TC I am going to install in the G .. Which has over 600whp ... You could floor it on wet or dry roads and not lose control....
So videos of my car will be boring
Old Dec 8, 2009 | 05:33 AM
  #2282
IIQuickSilverII's Avatar
IIQuickSilverII
are you just adjusting boost levels with wheel hub spin, or rpms or something(i guess in that case you arent hitting full boost until you get traction)...other ems systems can do this...
Old Dec 8, 2009 | 05:36 AM
  #2283
str8dum1's Avatar
str8dum1
wheel slip sucks, and I'd hate to see that anyhow.
i wanna see how fast that tach jumps and the mph needle pegs
Old Dec 8, 2009 | 06:58 AM
  #2284
BrianLG35C's Avatar
BrianLG35C
What TC? Racelogic?
Old Dec 8, 2009 | 08:50 AM
  #2285
XKR's Avatar
XKR
It reads Rpm, wheel spin, wheel position. And a few other things. Its almost the same one that was just aproved for use in Formula1....
I did have the RaceLogic.... But Sharif found out that it would not work with the injectors that I have..... So it was returned.
Someone owed me a favor and sent me this not for street use item
it's a full computer by itself....
Old Dec 8, 2009 | 09:03 AM
  #2286
redman333's Avatar
redman333
I don't know much about trac control setups so forgive my ignorance if this is something simple, but is this a plug and play setup or is it something that has to be setup or adjusted. Also is the trac control setup you have coming something for sale kor not cause I'd be interested in it if its for sale or if I can duplicate it. BTW I'm not mechanically iliterate but just never looked into these setups before.
Old Dec 8, 2009 | 09:32 AM
  #2287
ttg35fort's Avatar
ttg35fort
Professional
Mike, what is the traction control unit you are using? PM me if you don't want to post it here.
I was seriously considering the Race Logic unit. I have HKS 1000 cc fuel injectors, so I'm assuming that it won't work on my car either.
Old Dec 8, 2009 | 09:40 AM
  #2288
XKR's Avatar
XKR
No....the RaceLogic was not plug and play....and this néw one I will have installed is far from plug and play also.
The RaceLogic is around $2000....the other one is a race team based setup that's not available to the public.... Well atleast not yet... And I am sure it wlll be in the 15-20K range.
Old Dec 8, 2009 | 09:52 AM
  #2289
ttg35fort's Avatar
ttg35fort
Professional
$15-20k - Ouch
FYI, RaceLogic dropped their pricing since you bought yours. In June I was quoted $741.47 directly from RaceLogic.
Old Dec 8, 2009 | 09:56 AM
  #2290
Nexx's Avatar
Nexx
Mike, what kind of rubber do you have in the rear? errr you know what i mean.
Old Dec 8, 2009 | 10:00 AM
  #2291
XKR's Avatar
XKR
Originally Posted by ttg35fort
$15-20k - Ouch
That price is without the digital control.... They have many different models...it'd like buying an Fcon... You have the base price.... And then you have the loaded price.
Old Dec 8, 2009 | 10:08 AM
  #2292
XKR's Avatar
XKR
305 x 25 x 20....Yokahama Advan.
Old Dec 8, 2009 | 10:28 AM
  #2293
str8dum1's Avatar
str8dum1
sweet, that TC unit sounds extremely complicated and most likely will not be close to setup by Zdayz. might as well forfeit right now
Old Dec 8, 2009 | 10:34 AM
  #2294
Nexx's Avatar
Nexx
possible to go any wider? 315/25/20 maybe?
Old Dec 8, 2009 | 11:12 AM
  #2295
XKR's Avatar
XKR
Nahh.... Someone will fly in to help with the install
315 would fit.... But 305 is what Yokahama will send me..... I am lucky to get 305... Because 295 was the widest they were willing to go.
Old Dec 8, 2009 | 11:22 AM
  #2296
str8dum1's Avatar
str8dum1
wider isnt what matters, tread compound is what matters at that power level. guys are going 7-8sec 1/4 miles with narrower tires and more HP (the 10.5 classes)
I'd be interested to know what tires IP had on during their video. I'd bet DR's.
Ahh and I thought you going to give Sharif a heart-attack with "hey install this and make it run right in 2 months" Does the new TC setup have its own set of sensors and all that jazz? at 20k i bet it would. Will it assimilate into the FCON?
Old Dec 8, 2009 | 11:29 AM
  #2297
Nexx's Avatar
Nexx
for sure man but with 20's race compounds arent an option.
Old Dec 8, 2009 | 11:42 AM
  #2298
XKR's Avatar
XKR
I assume Chris was talking for a road course where wider is better... Because he knows that I don't drag race.
I have put alot of demands on Sharif.. And I felt it would not be fair to throw this on him at this point... So I will get him the help to install it.
I would be guessing if I answered the TC sensor question..... All I was told is that it can work alone or work with existing setup. I was told it does read the ABS... Steering position.... Pedal position...wheel speed... RPM.... And so on...
Alot of my friends in racing are aware of this car.... I was at a testing in FL and mentioned the dyno results and asked them for help with traction because the RaceLogic fell through.
Old Dec 8, 2009 | 11:44 AM
  #2299
Chris@FsP's Avatar
Chris@FsP
Vendor - Former Vendor
I'll take two.
Old Dec 8, 2009 | 11:47 AM
  #2300
str8dum1's Avatar
str8dum1
he Advans are not R compound are they? a same sized or smaller R888 or RA1 would grip better than any width street tire. But I assume you have a sponsorship deal with yokohama?
thats pretty slick it ties in with the stock sensors. Checking up on some of those aftermarket TC setups will make for some good after dinner reading.
