Would this turbocharger work?
Old Feb 19, 2009 | 06:59 PM
brink2012's Avatar
brink2012
Default Would this turbocharger work?
Looking for a cheap hp upgrade..
What all extra would I need if I got this kit? Could I leave my motor stock?
http://cgi.ebay.com/ebaymotors/POWER...ayphotohosting
Old Feb 19, 2009 | 07:09 PM
Spork's Avatar
Spork
Old Feb 19, 2009 | 07:15 PM
Cass007's Avatar
Cass007
Bro.... that kit is teh hotness!!! You should PM Doug or Alberto, I think they both had/have this same kit.
To answer your question, the stock block power should handle it, but just barely.
Old Feb 19, 2009 | 07:18 PM
Z33_kid's Avatar
Z33_kid
nooo
Old Feb 19, 2009 | 07:19 PM
CUL8ER's Avatar
CUL8ER
In my opinion RUN,that has to be the cheapest set up I have ever seen.The price that you would pay to have that garbage installed would be 3-time the amount of the kit if you could call it a kit?.I would do what I and everybody else save,save and save then after saving if you do want to increase the horse power a procharger is(cheaper) a good way to go,reported reliable on stock internals but only to 400 at the wheels.Then you have turboschargers and twin turbos,while single turbos are cheaper.when it comes to custom piping it gets expensive
Blackbird CPV35's Avatar
Blackbird CPV35
It would work but you need to buy 2 kits, thats what I did and I have a 1200 hp twin turbo G35
Old Feb 19, 2009 | 07:31 PM
iflyjets86's Avatar
iflyjets86
dont listen to these haterz man. that kit looks good. just make sure with something like that kit you keep the boost really high b/c small turbos dont run well on low boost. if you boost high,u have a lower chance of an engine failure. but they say that the kit itself has a low failure rate, so thats good
Old Feb 19, 2009 | 07:42 PM
SchismX's Avatar
SchismX
Old Feb 19, 2009 | 07:44 PM
kyx4n's Avatar
kyx4n
compared to the price of normal twins, you could buy 10 of the ones from ebay..
Old Feb 19, 2009 | 08:02 PM
davidmcc's Avatar
davidmcc
Old Feb 19, 2009 | 08:05 PM
HeyItsDan's Avatar
HeyItsDan
Ey man... I got that kit. I walk civics and scions all day baby.
Old Feb 19, 2009 | 10:36 PM
QuicksilverZ33's Avatar
QuicksilverZ33
ellowell
Old Feb 20, 2009 | 01:31 AM
brink2012's Avatar
brink2012
does anyone really have this kit lol? I asked what else is required when a turbo is installed.. regardless of what kit I get. I want to keep the motor as stock as possible.
Old Feb 20, 2009 | 02:41 AM
chopperman's Avatar
chopperman
You Sir fail.
Dont you read all the sarcasm in everyones post's?
Dont buy that kit, it might look good but it is a bunch of shitty no name parts.
Old Feb 20, 2009 | 06:12 AM
UMW350Z's Avatar
UMW350Z
Quit knocking my products guys. A guy's gotta eat
Make sure you hook up the round pipes directly to the outlet of the hot side and connect them to the "T" adaptor or else it won't hold boost correctly. If you mount the turbo in the car cabin, you can eliminate the need for a heater core saving a LOT of weight. That is the main advantage over most of the TT and ST kits out there.
Good luck...you are gonna need it
Old Feb 20, 2009 | 06:37 AM
bryan@Z1's Avatar
bryan@Z1
Vendor - Former Vendor
"NOTICE THE AEM EMS FUEL MANAGEMENT INSTALLED IN THE PLASTIC SEE THROU BOX!"
I'm pretty sure that is a Tuperware container. I bring my lunch to work in those.
Old Feb 20, 2009 | 06:39 AM
athenG's Avatar
athenG
I want to jump the wagon and just flame you silly!!! That turbo is small!! You cant just buy any turbo and think you are good, the turbo size MUST match the engine and should be able to push enough CFM to satisfy the engine..
Old Feb 20, 2009 | 06:57 AM
SoundPerformance's Avatar
SoundPerformance
Sound Performance
Awww, come on guys, it's so simple maybe you need a refresher course. Heyya! It's all ball bearings nowadays. Now you prepare that Fetzer valve with some 3-in-1 oil and some gauze pads, and I'm gonna need 'bout ten quarts of anti-freeze, preferably Prestone. No, no make that Quaker State.
Old Feb 20, 2009 | 07:03 AM
thom000001's Avatar
thom000001
Can I borrow your towel, my car just hit a water buffalo
