Vortech installation problems
Old Feb 26, 2009 | 12:16 PM
Xendric's Avatar
Xendric
Originally Posted by tylerxfire
anniversary edition i beleive may have a different kit, i think there is a kit for just the 05 anniversary edition i remember seeing somewhere, are u sure u have the right kit?
My car is a 2005 anniversary (revup).
Vortech's installation manual describes the installation in the same section for both MY's (2005-2006).
Old Feb 26, 2009 | 12:20 PM
tylerxfire's Avatar
tylerxfire
also looks like there is only a tuner kit for the 05 revup motor and not a complete kit...
http://www.superchargersonline.com/p...VehMake=Nissan
Old Feb 26, 2009 | 12:21 PM
350z006's Avatar
350z006
I have a revup Vortech (yes, the blowers between non-revup and revup are the same)...I did the install myself, I didn't have to tilt the blower down...that's something you really shouldn't have to do...
However, I have the V2 blower so i couldn't verify for sure if you have the right blower or not....I would contact Vortech and give them the serial # of your blower to verify they sent you the right blower...or you can show them the pics I posted and ask them if a 350z blower should really look like that...
Originally Posted by Xendric
YES! I noticed that too and at first I was certain that was the problem.
But then Vortech told me the only different parts between a revup and a non-revup are the cog pulley, the mounting plate and some miscellaneous bolts and spacers. I specifically asked them today if the blower is identical for the two models, they said yes.
And yes, mine is a V3, I don't know if it should be like that though.
I noticed your blower's intake is tilted way down compared to mine. Did your shop do it manually or did it came like that?
Xendric's Avatar
Xendric
i did the install myself on mine took 3 days... what is ur part number like i said i beleive there is a specific kit for the 05 revup anniversary edition...think this is it V4NZ218-120L
says 05-06 revup, then there are other kits for just 05 and other kits for just 06 it looks, little things could be different...
Where did you find that part no.? I can't even find it listed on the manual, and they have every model year in there.
I thought mine should have been the 4NZ218-060L
tylerxfire's Avatar
tylerxfire
take a look there and u will know what im trying to say...looks like theres a kit for 05's non-revup, and 06 revup kits, but then there is a kit for 05-06 revup and its only a tuner kit???...idk, would just suck to be wasting ur time with the wrong kit, i mean it can really only go in one way
Old Feb 26, 2009 | 12:27 PM
Chef-J's Avatar
Chef-J
Booooosstt!!
yes the bolt u take out on like the first couple steps is re-used for the cog tensioner bolt its a long bolt u pull right out during ur uninstallation of things u will see...those bolts u have there chef are all for mounting the blower to the bracket and the bracket and blower to the motor..
Gotcha, thanks
Old Feb 26, 2009 | 12:29 PM
Chef-J's Avatar
Chef-J
Booooosstt!!
Mine is non-revup, V3 ,i don't think there is big diff V2 rev and V3 rev
Here is couple of pictures.
How come mine came in with black BOV? lol
Edit: OP did you check every parts when you received them?
Old Feb 26, 2009 | 12:35 PM
05Z33's Avatar
05Z33
Now, if I remove the black spacer, which we tried, the ribbed pulley on the jackshaft (the upper right one as you look at the engine bay from the front, on the mounting plate) is hitting the blower's intake, and it will not sit properly - there's just not enough clearance.
That ribbed pulley is the serpentine pulley. Make sure it is a 3.12 and not a 3.33. The rev up uses the smaller one of the two. maybe that could be the reason why it won't fit. Also it looks like the blower is mounted correct on the bracket.
Old Feb 26, 2009 | 12:39 PM
tylerxfire's Avatar
tylerxfire
good point make sure its 3.12 for the revup stock pulley, and also if anyone has a 3.12 to sell pm me
Old Feb 26, 2009 | 12:40 PM
tylerxfire's Avatar
tylerxfire
whats up with the black bov chef??lol...havent seen that happen yet
Old Feb 26, 2009 | 12:42 PM
05Z33's Avatar
05Z33
I've seen red ones before.
Old Feb 26, 2009 | 12:47 PM
350z006's Avatar
350z006
That housing looks pretty flat, like the OP's blower...I guess that's the way the v3 looks...
And Chef , I'd be more than willing to trade you a blue BOV for you black one...I think it looks cool!
Old Feb 26, 2009 | 12:49 PM
Xendric's Avatar
Xendric
This serpentine pulley was replaced when I got the right parts the second time around, and it was already placed on the revup mounting plate. I haven't measure it, tbh, but it should be the right one, as it came preinstalled on the revup plate.
Also, it's not the pulley that hits on the intake of the blower if I remove the black spacer, but rather the bolt that holds it in place on the plate.
So, 3.12 or 3.33, the center should be sitting on the same place, right?
Old Feb 26, 2009 | 12:51 PM
Chef-J's Avatar
Chef-J
Booooosstt!!
I'm also thinking to just put 3.12 pulley when i install blower; looks like i have to take out blower again when i upgrade to 3.12 later...
Doesn'tt even hav the vortech logo on it lol
Old Feb 26, 2009 | 12:55 PM
Chef-J's Avatar
Chef-J
Booooosstt!!
haha, i like new
Old Feb 26, 2009 | 01:00 PM
350z006's Avatar
350z006
Talking
I have a 3.12 pulley...you and tyler can fight over it!
Old Feb 26, 2009 | 01:01 PM
Xendric's Avatar
Xendric
I found this pic on the installation manual.
So I guess the black spacer has been correctly installed by my shop.
Back to the start again then, I'm gonna cry!
Old Feb 26, 2009 | 01:02 PM
  #38
05Z33's Avatar
05Z33
After looking around on here I saw a revup kit with that spacer in place, so my other theory is out. Let me do some more research and I'm sure we can figure this out.
Old Feb 26, 2009 | 01:05 PM
  #39
05Z33's Avatar
05Z33
No need to fight. I have one sitting right here. PM me an offer and it's yours.
Old Feb 26, 2009 | 01:09 PM
  #40
tylerxfire's Avatar
tylerxfire
haha, well i just ordered plugs and berk high flows today so i will be buying my pulley next week or week after, i still have a good month before my z leaves the garage due to winter, and its only leaving the garage to go get tuned, but i will need a 3.12 so just pm me ur best price if u could guys, ill take it next week most likely...i would do the 2.87 but i wanna keep my warranty so ill wait on that, but i am not even gonna mess with this 3.33
