Well I found my exhaust leak
Old Feb 26, 2009 | 07:39 PM
Blackbird CPV35's Avatar
Blackbird CPV35
Default Well I found my exhaust leak
massive backfire maybe?
Old Feb 26, 2009 | 07:54 PM
JoeDirtPharmD's Avatar
JoeDirtPharmD
Oh sweet - a new Maxim!
Old Feb 26, 2009 | 08:02 PM
Blackbird CPV35
i just got it in the mail
Old Feb 26, 2009 | 08:04 PM
matix101vz's Avatar
matix101vz
really i got that issue last month
Old Feb 26, 2009 | 08:08 PM
Blackbird CPV35
well i just got a new subscription so they are probably sending me the last issue
Old Feb 26, 2009 | 08:49 PM
Chef-J's Avatar
Chef-J
Booooosstt!!
Damm pain in da a$$ spot! ( talking about gasket...lol)
350 Rookie's Avatar
350 Rookie
24 pages of the hottest models on earth!?!?!
You mind scanning those pages please.
Old Feb 26, 2009 | 10:02 PM
Blackbird CPV35
i had to take the engine out to get to it easily
Old Feb 27, 2009 | 04:10 AM
Cass007's Avatar
Cass007
+1 on the backfire theory. Did you notice a change in the exhaust note recently? Possibly pushing raw fuel through the system for some reason, causing it to ignite down by the turbos - I've read about this with anti-lag settings for turbos.
Old Feb 27, 2009 | 05:20 AM
niceguyyy01's Avatar
niceguyyy01
Check the manifold or header for straightness. Do the same with the head. Lay a flat edge along it and make sure they are both perfectly square. A backfire should not do this if everything is tight and flat. Turbo manifolds and headers see an extreme amount of heat and therefore can warp very easily. Check it before it goes back together.
Old Feb 27, 2009 | 05:45 AM
Blackbird CPV35
ill check for warpage but I believe it was because the nut backed off the stud, when I took the engine out the nut was almost completely off of the stud
Old Feb 27, 2009 | 07:34 AM
GreenGoblin's Avatar
GreenGoblin
ya that could be a problem. Good luck with the repairs
Old Feb 27, 2009 | 05:07 PM
tig488's Avatar
tig488
as above, loose studs/nuts that cause exhaust gas to go between the manifold and head is a very common cause of gasket burnout.
Old Feb 27, 2009 | 05:35 PM
UMW350Z's Avatar
UMW350Z
for the dumb ones here....that is the exhaust manifold gasket?
Old Feb 27, 2009 | 05:53 PM
Blackbird CPV35
yes it is the one that goes between the turbo manifold and head
anyone have a good solution to keep the nut from backing out again? I would use loctite but its only rated to 450 degrees
Old Feb 27, 2009 | 07:02 PM
Smoothy34's Avatar
Smoothy34
http://www.pulpandpaperonline.com/ar...?VNETCOOKIE=NO
http://www.solomotoparts.com/catalog...k-p-25419.html
Old Feb 27, 2009 | 08:16 PM
Ouch. Doubt if you could have found a worst spot. Sorry.
Old Feb 28, 2009 | 08:20 AM
Blackbird CPV35
The only place I can find that high temp loctite is Fastenal and they want $150 for a 300 gram tube of it. Any idea how high temp that threebond is rated
Old Feb 28, 2009 | 09:55 AM
Smasher's Avatar
Smasher
My builder (SG-Motorsports) is going to use Nord locks. My APS TT was originally installed without taking the eng. out by another shop and every single nut was loose, one was missing entirley.
http://www.youtube.com/watch?v=mgwmuZuJ02I
Old Feb 28, 2009 | 04:54 PM
Blackbird CPV35
WOOT, this is exactly what im looking for, good find!
