downpipe melted PS rack hardline..replacement?
Old Mar 6, 2009 | 04:26 PM
SnyperZ's Avatar
SnyperZ
Default downpipe melted PS rack hardline..replacement?
My downpipe on my PL kit melted a hole though the short hardline on the rack..(the one that starts in the center of the rack pointing up and goes over near the steering shaft..can a replacement be bought for this line?
Old Mar 6, 2009 | 04:49 PM
Glex25's Avatar
Glex25
Does it have fittings?
If so you can make your own hard line
Pictures would help
Old Mar 6, 2009 | 05:10 PM
SnyperZ's Avatar
SnyperZ
Pictures would help
Yeah it has fittings on both ends.
Old Mar 6, 2009 | 07:15 PM
Sharif@Forged's Avatar
Sharif@Forged
Forged Performance
It's a high pressure line. Yes it's replaceable part from Nissan.
Old Mar 6, 2009 | 09:26 PM
rrmedicx's Avatar
rrmedicx
Definitely replaceable thru Nissan. I tried to make a custom line set-up for my friends '06 to better accommodate the Turbonetics set-up and OMG what a pain in the A$$. We ended up cutting off the OEM fitting and welding it onto a more common type fitting to use SS hose in between. The thread and pitch are unavailable to the common market (us). Nissan has done there part to keep that thread and pitch design under wraps, which makes replacing with anything other than stock virtually impossible.
Shouldn't take Nissan more than 3-5 days to source.
Good Luck.
Old Mar 7, 2009 | 03:34 PM
superchargedg's Avatar
superchargedg
Damn Noobs
And boy what a pita it is to replace that line assembly.
Old Mar 7, 2009 | 04:13 PM
SnyperZ's Avatar
SnyperZ
Its pretty easy in my case..the engine is out. The line came off in 2 min.
Old Mar 7, 2009 | 04:28 PM
failsafe306's Avatar
failsafe306
i had to replace mine, tore it up removing the engine/trans. whoops lol. not too expensive if i recall correctly.
Old Mar 7, 2009 | 06:33 PM
SnyperZ's Avatar
SnyperZ
thats good to hear.
Old Mar 8, 2009 | 08:50 AM
superchargedg
Damn Noobs
I was thinking the engine was still in the car cause mine was a ***** to replace.
Old Mar 8, 2009 | 11:19 AM
GreenGoblin's Avatar
GreenGoblin
I replaced mine with a high pressure soft line
Old Mar 8, 2009 | 11:27 AM
SnyperZ's Avatar
SnyperZ
Explain?
Inspatatrac
Sep 8, 2015 02:12 PM
dragon11689
Sep 7, 2015 02:47 PM
ddegrande21
Sep 6, 2015 11:15 AM
HEUGE
Mar 22, 2003 06:30 PM
az240z
Cleaning & Detailing
Jan 4, 2003 12:47 PM
