P0345
Old Mar 6, 2009 | 11:07 PM
down_shift's Avatar
down_shift
Default P0345
I just pulled this code which is still Pending..
I have a pretty dead battery.. had to jump it tonight.. car has been at the shop for about 10 months.
Code this be caused by a weak battery instead of a CAS problem?
Old Jul 25, 2010 | 10:54 AM
G35cTT's Avatar
G35cTT
0345 is for the cam position sensor located on the drivers side, I had a weak battery as well and threw this code and the 0340 replaced both sensors and my car still does not start and the 0345 code came back so curious to see what the shop tells you?
Old Jul 25, 2010 | 03:38 PM
wannabuy350z's Avatar
wannabuy350z
^you may have a broken cam. pull the sensor out and if you dont feel the cam, i am sure that the last section of your cam is broken and stuck.
Old Jul 26, 2010 | 04:21 PM
G35cTT's Avatar
G35cTT
would the car crank still though?
Old Jul 28, 2010 | 11:44 AM
G35cTT's Avatar
G35cTT
Ended up being crankshaft position sensor
changed all sensors and car still won't start.
marques1
Dec 14, 2014 06:01 PM
BRIAN10197
Mar 23, 2014 09:54 AM
sboarderk03
Mar 30, 2012 04:55 PM
TheSyn3rgist
Jul 20, 2011 08:54 AM
