Who's knocking....Oh nevermind that is my motor
Old Apr 20, 2009 | 05:20 AM
  #41
Glex25's Avatar
Glex25
Yep time to rebuild the block =0((
Old Apr 20, 2009 | 05:31 AM
  #42
djamps's Avatar
djamps
Ohh nooo!!!!
Old Apr 20, 2009 | 05:33 AM
  #43
rrmedicx's Avatar
rrmedicx
There is no doubt in my mind after seeing these pics that the bearing material has infiltrated every part of your motor. Looks like a full rebuild is in store.
Just check to see if the main bearings fried and whether or not the crank is still straight?
Then send the turbos out to be checked as well. PM sent.
Old Apr 20, 2009 | 06:18 AM
  #44
leeboyNY's Avatar
leeboyNY
Kimchi Eater
That sucks bro!! Good luck with repair.
Old Apr 20, 2009 | 10:32 AM
  #45
ADMAN's Avatar
ADMAN
Dayum
Old Apr 20, 2009 | 11:37 AM
  #46
Cass007's Avatar
Cass007
I know that sight all too well. I hope that some part of the motor and turbos are still good or you will have to replace eveything just like I did. Best of luck on the re-build man.
Old Apr 20, 2009 | 03:12 PM
  #47
chopperman's Avatar
chopperman
Alright well, Im guessing that I will need new Pistons. I have a spare longblock that I can get for $1000. Im planning on swaping out the rods and buying new pistons and cams and putting them on the new block.
Old Apr 20, 2009 | 03:36 PM
  #48
str8dum1's Avatar
str8dum1
as cass said, you might need a whole lot more than that
Old Apr 20, 2009 | 04:35 PM
  #49
chopperman's Avatar
chopperman
who do you guys recomend to send the turbos too?
Old Apr 20, 2009 | 05:11 PM
  #50
j.arnaldo's Avatar
j.arnaldo
...scary...Good luck.
Old Apr 20, 2009 | 07:18 PM
  #51
35Z's Avatar
35Z
Default Greddy twin turbo's
Which Greddy turbos do you have? The older 18G's are likely more available than the more recent 20G's. Try contacting Sharif.
Old Apr 20, 2009 | 07:25 PM
  #52
chopperman's Avatar
chopperman
I have the 18g's
Old Apr 20, 2009 | 07:26 PM
  #53
35Z's Avatar
35Z
Default Engine Re-build
I suggest checking the oil pick-up/oil pump/ bottom end for evidence of brass fillings/bent parts/heat damged parts before assuming the top-end is is ok and is re-buildable. I have "been their done that" spending minimum dollars only to find out that some little part that was overlooked in the re-build cause the engine to fail again!
Good luck!
Old Apr 21, 2009 | 07:42 AM
  #54
rrmedicx's Avatar
rrmedicx
Turbos go to Forced Performance.
Rebuilding them to 18G's is like $1600.
To make them into 20G's is like $1800. (prices subject to change)
Old Apr 21, 2009 | 07:47 AM
  #55
rrmedicx's Avatar
rrmedicx
You may not need pistons. Have them checked before you start spending money. Maybe just a set of new rings.
If only 1 rod went bad (not sure yet), see if you can buy just 1 replacement and have them all weight balanced before re-installing. That might save some $$. Just a thought.
Have your cams checked out as well. Let me know if you need another set of stock cams. I have a set handy.
Old Apr 21, 2009 | 06:52 PM
  #56
Mr_pharmD's Avatar
Mr_pharmD
damn that sucks.
did u figure out what was the cause of the knock?
Old Apr 21, 2009 | 07:00 PM
  #57
Motormouth's Avatar
Motormouth
how was your oil level when you checked and found the metal? what about damage to your oil pan from the off-road?
sucks to hear.
Old Apr 21, 2009 | 07:15 PM
  #58
chopperman's Avatar
chopperman
Oil was full, actually before I left the tuner a couple days before, he said it was just a tad about full. Can that of cause it? The oil pan was fine after I went offroad, no damage what so ever. I will be taking about the longblock tomorrow after work. More pictures to come.
Old Apr 22, 2009 | 03:02 AM
  #59
Cass007's Avatar
Cass007
If you want to comparison shop on the turbo repairs here are the guys I have used:
Blouch Turbo, Inc.
1925 State Route 72 North
Lebanon, PA 17046
ph: 717-865-3276
fax: 717-865-6478
http://www.blouchturbo.com/contactus/
Ask for Mike
Be sure on disassembly that the bearing material did not score all the bearing surfaces throughout the motor, this is what happened in my case and ruined every part of the motor since all the surfaces had been machined when it was built and then reassembled a second time. Not enough material left on surfaces to make them smooth again. I hope this is not the case for you. Best of luck and keep us updated on your progress.
Old Apr 22, 2009 | 09:02 AM
  #60
Mr.Squeeze's Avatar
Mr.Squeeze
That suck man good luck on your rebuild.
