Who's knocking....Oh nevermind that is my motor
Old Apr 22, 2009 | 12:46 PM
  #61
andypandy's Avatar
andypandy
Damn... I too had a spun bearing on my built block awhile back. I had to get the rod replaced and re-blueprint the block with a new crank. Very expensive lesson learned! Now I check the oil every week.
How were you driving prior to the "spirited runs"? Do you have wideband gauges instead of reading through a laptop connected to the Haltech? I am guessing the ditch did some damage to the fuel lines or wideband sensors to cause you to go lean?
Old Apr 22, 2009 | 07:20 PM
  #62
chopperman's Avatar
chopperman
Bump the motor is apart now. It looks alot better then I thought. two of the cams on the driver side are a little damaged, but I hope it can be machined out. Pics
Old Apr 22, 2009 | 07:23 PM
  #63
rookie's Avatar
rookie
Is this the cylinder that the bearing spun? Looks like slight contact with the head.
Old Apr 22, 2009 | 08:20 PM
  #64
chopperman's Avatar
chopperman
Im not sure. I couldnt tell which bearing it was. Its off to the builder tomorrow.
Old Apr 22, 2009 | 09:32 PM
  #65
rookie's Avatar
rookie
That's cylinder 5. Pretty sure you'll probably be able to push/pull the rod a little that spun.
Old Apr 22, 2009 | 09:53 PM
  #66
LMBLF8's Avatar
LMBLF8
Damn man sorry to hear about this Is the shop in KS? Speaking of which, how you liking/disliking it out there?
Old Apr 23, 2009 | 03:55 AM
  #67
Cass007's Avatar
Cass007
If you have bearing material in the cam journals, which its looked like in one pic, then the rod connected to the bearing that spun will be able to be moved side to side by hand. You will see on the crack where the bulk of the damage is. Tough call on the cams - take EVERYTHING to the best/trusted engine shop and have it all evaluated.
Do not offer to buy any parts from the engine shop, that way they will give an honest account of what can be saved and what can't. Good luck moving forward, this was where my stall point was, can't fix things till you know whats broken
Old Apr 23, 2009 | 05:53 AM
  #68
Mr_pharmD's Avatar
Mr_pharmD
well, if u need stock cams, I just replaced mine with nismo R so if u need some cheap ones pm me.
Old Apr 23, 2009 | 05:14 PM
  #69
superchargedg's Avatar
superchargedg
Damn Noobs
I think those cams are now junk.
Old Apr 23, 2009 | 05:32 PM
  #70
chopperman's Avatar
chopperman
Just got back from the shop. They were very confident that everything is going to be able to be resurfaced. They are tearing it down on monday so a final report will come.
Old Apr 29, 2009 | 05:16 PM
  #71
chopperman's Avatar
chopperman
I have a question on a part that I cant seem to find where it goes. Its looks like a little screen filter. Take a look at the pics I attached.
Attached Thumbnails Who's knocking....Oh nevermind that is my motor-img_0062-1-.jpg   Who's knocking....Oh nevermind that is my motor-img_0061-1-.jpg   Who's knocking....Oh nevermind that is my motor-img_0060-1-.jpg
Old Apr 29, 2009 | 05:27 PM
  #72
rrmedicx's Avatar
rrmedicx
Could you go over your parts in this build again. It might belong to an aftermarket piece? Looks like an oil filter screen or even a basic fuel filter screen.
Fixxxercask
Nov 9, 2015 11:10 AM
