Go Big Or Go Home!! PPIHC 928 '09
Old Apr 13, 2009 | 05:39 PM
Quamen's Avatar
Quamen
Default Go Big Or Go Home!! PPIHC 928 '09
Pre-Note: I understand that this would normally be in the a different forum. However, given that I am part of the FI forum and others like to post crazy builds of other cars in here that are related to FI I figured it would be acceptable.
As many may know, I am the Crew Chief for 928 Motorsports. Keeping it simple, the crew at 928 Motorsports has made some huge changes this year to our Porsche 928 for the Pikes Peak International Hillclimb that I would like to share with you guys. The big changes are the following:
1) EFI Conversion from Mechanical Fuel Injection
a. 65lb injectors
b. Aeromotive rising rate FPR
c. Electromotive Tech GT Standalone Engine Management
d. Electromotive DFU ignition
e. Custom Billet Fuel Rails (made by myself)
2) Revised Supercharger Setup
a. Modified Super XB-1A headunit with 928M Billet BD-11 Impeller mated to it (modified by myself)
b. Improved Supercharger Intake
c. Custom made 8-rib crank pulley (made by myself)
3) Revised Intercooler Setup
a. Switched from air-to-water intercooler setup to air-to-air front mount intercooler setup.
4) Extensive Chassis Lightening
a. Sound deadening material removed from underbody
b. Light weight thin gauge exhaust w/o mufflers
c. Metal cutout where ever possible.
5) Improved Aerodynamics
a. New custom chin splitter dubbed the "Shinsplitter" and "Skinsplitter"
b. New carbon fiber adjustable wing
6) New Custom Intake Manifold w/ air bells inside
I'm sure I am forgetting a ton of things but these are the biggyies. Carl at 928 Motorsports along with the crew and I have put a ton of hours into this car over the winter. Racing season is upon us now in Wisconsin so we are excited to get this thing to the dyno in the next two weeks and then go racing!! Anyways, here is the real goods that makes this thread have some value
Let me know what you guys think!
Old Apr 13, 2009 | 05:45 PM
BlinkerFluid's Avatar
BlinkerFluid
Outstanding!
Excellent fab work. How much power does it put down?
Old Apr 13, 2009 | 05:51 PM
Quamen's Avatar
Quamen
Originally Posted by BlinkerFluid
Outstanding!
We don't know yet. But on our black 928 with a smaller blower and less mods we hit 420 wheel. We are hoping for mid 500whp reliably... maybe more
Old Apr 13, 2009 | 06:00 PM
Chef-J's Avatar
Chef-J
Booooosstt!!
YOU GOT TO BE FA*KING KIDDING ME!!
awsome job quemen, i'm jealous...
chefj
Old Apr 13, 2009 | 06:17 PM
35Z's Avatar
35Z
Default 928 Supercharge Changes
Like the direct path from the supercharger to the intercooler however, why is the IC out to engine plumbed to the back side of the engine (heat/space issues)? Why did you switch from a air-to-water IC to an air-to-air IC? How much weight did the car drop with these changes? Does it handle better?
Old Apr 13, 2009 | 06:34 PM
TurboTim's Avatar
TurboTim
Vendor - Former Vendor
I likey. Why did you guys use the older stlye 928 throttlebody instead of the S version which could have come in from the back? It looks like the air inlet is at the bottom of the plenum and if it just dumps into a big open space you can lose velocity.Just wondering. It is pretty trick *** 928 though.I have to admit though,I hate working on those damn things.Such a pain the *** but it looks like you guys made alot of changes that makes it much easier to work on.
Old Apr 13, 2009 | 06:41 PM
Resolute's Avatar
Resolute
Cool stuff, I'll be looking for you guys on the Peak this year.
Will
Old Apr 13, 2009 | 06:49 PM
Quamen's Avatar
Quamen
We made a solid model of both this manifold and the stock manifold and put them through flow works to find out where we were losing pressure and or velocity. This was the best compromise we could come up with and was also based on have an air-to-water intercooler intially. However, mid way we switched to the air-to-air which basically defeated the purpose of the TB routing. However, the manifold was already made so we just left it. Especially since we have a stroked 32V waiting in the wings and this is actually our spare motor for testing of the Electromotive EMS. After PPIHC, the 6.4L 32V with a SCAT crank and our CNC ported heads will be going in to prepare for Bonneville next year.
In regards to working on the car I agree with you. The 928 is PITA. However, we have made the entire front end one piece and quick release. So if you want to do anything to the engine the car has to be worked in the manner shown above which is nice. We even did things like switch the oil cooler lines in the block from metric to AN fittings for ease of working on along with being able to replace stuff at races without carrying a ton of hard to find metric fittings around.
I will post some pictures of the inside of the intake manifold soon.
Old Apr 13, 2009 | 06:55 PM
Quamen's Avatar
Quamen
Old Supercharger Setup
Intake Manifold
Removable Front Clip and Slicks:
Old Apr 13, 2009 | 06:59 PM
Quamen's Avatar
Quamen
Since you have worked on the 928 maybe you might recognize the "T" for the air filters as the factory center piece for the "pipe organ" intake manifold that was only avaliable in '85. It is quite a neat little piece actually.
Old Apr 13, 2009 | 07:17 PM
TurboTim's Avatar
TurboTim
The inside of the manifold is sick.Yes, it is hard to miss those two huge airfilters. Wont have to worry about starving for air with those suckers. I only worked on a few of them. We were going to do a twin turbo system for the 928 about 10 years ago but there was really not much interest so we scrapped the idea.
For anyone that doenst know about the 928.That is one plush *** car from the factory with decent power out of the V8. The look of the shark is well not for everyone but the interior of the S4 and GTS is so incredible, it makes are plastic interior Nissans feel like Yugos.
If you guys run into any issues or troubles with the TECGT, let me know. I have been tuning those for many,many years (since the TEC2 LOL)and know alot of little secrets.
Old Apr 13, 2009 | 07:22 PM
Quamen's Avatar
Quamen
Pictures of the lightly modified interior:
I wish the Z could look this good gutted...
Old Apr 13, 2009 | 07:55 PM
CUL8ER's Avatar
CUL8ER
Pretty slick, from one 80's tricked out Porsche owner to another nice job!
Old Apr 13, 2009 | 07:58 PM
galant350z's Avatar
galant350z
you insane!!! bow to you sir.
Old Apr 13, 2009 | 08:03 PM
WP350z's Avatar
WP350z
Damn Good Job!
thats so sickkkkk!
GreenGoblin's Avatar
GreenGoblin
so nice
Old Apr 13, 2009 | 08:25 PM
SirSpeedyZ's Avatar
SirSpeedyZ
wow that car is sick
Old Apr 13, 2009 | 08:29 PM
wannabuy350z's Avatar
wannabuy350z
wow, amazing...
Old Apr 13, 2009 | 08:41 PM
Dynosty's Avatar
Dynosty
Looks like a really nice setup you have put together. More excited to see vids of it in action!!
Old Apr 14, 2009 | 03:54 AM
Quamen's Avatar
Quamen
Should have some videos of Road America very soon!
