Vortech Ceramic thrust 65K
Old Apr 14, 2009 | 09:46 AM
Vas@Extended's Avatar
Vas@Extended
Vendor - Former Vendor
I guess I'll give them a call and see post back on what they say.
Chef- what pulley are you talking about? I'm talking about the extra pulley to prevent slippage .
Tyler- yeah depending on what they say, I might just go with the minor rebuild . I would really like to run the 2.87 . I have the 3.12 too but I might as well do it now so
I don't get 2 tunes and waste $$$ down the road.
Old Apr 14, 2009 | 10:25 AM
cc1012's Avatar
cc1012
didnt read the whole post.... But if your looking for someone to do the rebuild. Just go to turbo people in Dobbs Ferry. There close to us and there vortech dealers. Im sure they could rebuild it and be reasonable.
Old Apr 14, 2009 | 10:40 AM
Vas@Extended
really?? Hmm... Do they have a website? Phone? Might be worth a try
Old Apr 14, 2009 | 03:28 PM
05Z33's Avatar
05Z33
A little oil coming out of your bypass might not be bad seals. You could just have some blow by from the PCV hose attached to the air filter. I would look in your intercooler pipes and see if you have any significant amount of oil in there first.
Old Apr 14, 2009 | 06:19 PM
CaneZMD's Avatar
CaneZMD
So Quamen, how hard is it to rebuild the blower?
Old Apr 14, 2009 | 06:31 PM
Vas@Extended
Im gonna check on that!. Its not really like leaking oil from the BPV.. its just like mist. Maybe your right
Thanks for the help
Old Apr 14, 2009 | 06:46 PM
Chef-J's Avatar
Chef-J
Booooosstt!!
Thanks for the help
So leaking isn't that bad?
Btw, you got my PM?
chefj
Old Apr 14, 2009 | 06:56 PM
Quamen's Avatar
Quamen
It is not that hard to rebuild a supercharger if you know what to look for and have the correct tools. Attention to how the bearings are pressed in and seat is the most important part. Seals are a breeze to do. I would say the hardest part is getting the old bearings out if you don't have the appropriate tools.
Old Apr 14, 2009 | 07:02 PM
str8dum1's Avatar
str8dum1
the bearings and impeller work as a pair. no sense to buy chi chi bearings on an impeller that isnt rated that high.
i would pull you charge pipes off your IC. If it looks like this... you need new seals
Old Apr 14, 2009 | 07:06 PM
y0shi's Avatar
y0shi
i don't know if this will help, but the Scion guys have a DIY on TRD(vortech) supercharger rebuild. I think you needed a special wrench to take a bolt off on the inside of the blower itself. They mention that the seals are very thin, so they upgraded to a better/beefier seal and bearings here's the link - check page 4 on the aforementioned thread
Old Apr 14, 2009 | 07:18 PM
Chef-J's Avatar
Chef-J
Booooosstt!!
^ Thank god, our font size is not that small..lol
Btw, good info yoshi! That must not a easy job..
chefj
Old Apr 14, 2009 | 07:28 PM
350 Rookie's Avatar
350 Rookie
Wait wtf. you got this installed already?
Old Apr 14, 2009 | 07:30 PM
Vas@Extended
Btw, you got my PM?
chefj
Yes sir I did! ill definitely try and lower the pulley! thanks for the heads up.
Its just mist from the bpv. its not dripping or anything. Iam going to order new seals anyways and replace them just to be sure since it isnt very hard to do.
Old Apr 14, 2009 | 07:34 PM
Vas@Extended
No, no.. iam waiting to get this problem solved b4 I come to you.lol
I think iam going to do the seals to be on the safe side. I took some of the blower out, there is no shaft play or anything at all.
Old Apr 14, 2009 | 07:36 PM
Chef-J's Avatar
Chef-J
Booooosstt!!
time to make a DIY replace vortech seals thread!!! So i can try it later......
Chefj
Old Apr 14, 2009 | 07:42 PM
Vas@Extended
Chefj
Old Apr 15, 2009 | 07:37 AM
cc1012's Avatar
cc1012
http://www.turbopeople.com/index2.php
There big into american muscle..... dont know how many Z/Gs theyve done but a vortech supercharger is a vortech supercharger so i dont think they can vary that much.
are you doing the install yourself??? Lemme know if you need a hand. You know im in the area. Never done a vortech install but im pretty mechanically inclined and i have air tools.
Old Apr 15, 2009 | 11:04 AM
  #38
Vas@Extended
Thank you sir! you got PM
Old Apr 15, 2009 | 11:35 AM
  #39
350 Rookie's Avatar
350 Rookie
hey vas, cc1012 can take care of you. hes closer anyways so just let him do it.
Old Apr 15, 2009 | 12:13 PM
  #40
Vas@Extended
Yeah we will see. chris ( cc1012 ) is only 10 min away so thats definitely a big plus
