Vortech + 85 degree = Killed my A/C.
Old Apr 21, 2009 | 10:27 AM
moog's Avatar
moog
wanna buy my air suspension?
Old Apr 21, 2009 | 10:29 AM
Chef-J's Avatar
Chef-J
Booooosstt!!
maybe couple months later, but now i can not spend any money on car.
Old Apr 21, 2009 | 11:20 AM
frankie945's Avatar
frankie945
chef i think Forged has ac lines I need one too will check it out to see how much they cost. I could have used my AC last saturday,getting warm up here.
Old Apr 21, 2009 | 11:46 AM
05Z33's Avatar
05Z33
The same thing happen to me only it wasn't the rubber hose; it was one of the thin aluminum lines that run from the radiator area. In my case the oil feed line was resting against the aluminum line and the heat from the oil feed line melted the aluminum. I had to cut it and use a brass union coupler. I then rerouted the oil line and wrapped it with a rubber hose in certain areas. Good luck with your repairs.
Old Apr 21, 2009 | 12:48 PM
Chef-J's Avatar
Chef-J
Booooosstt!!
That sounds not good. I haven't time to look at it yet but i don't think mine is that bad.
Oh yea, you have a TN kit. Yea let me know frankie! thanks
Old Apr 21, 2009 | 12:54 PM
Spork's Avatar
Spork
Is this the line below the Vortech unit that sits close to everything? When I installed my popcharger, I didn't like how it could rub in some places, so I wrapped the line and tightened on those hose clamps on the points that would contact metal. Not FI yet, but this is what I used.
Old Apr 21, 2009 | 01:16 PM
str8dum1's Avatar
str8dum1
ya take a pic to show which ac line you are talking about. i dont have any ac lines near anything that rubs. heat alone would not cause an AC line to leak, only rubbing.
Old Apr 21, 2009 | 02:30 PM
Chef-J's Avatar
Chef-J
Booooosstt!!
Only rubbing cause an AC line to leak, only place i can think of is under the blower. I have to go ahead lift the car up, but i'm lazy.
Old Apr 21, 2009 | 02:40 PM
Nexx's Avatar
Nexx
typical korean.
Old Apr 21, 2009 | 02:47 PM
iStan's Avatar
iStan
ZR
Originally Posted by Nexx
typical korean.
What's with the Koreans with Vortechs (Previously and Currently) in this thread.
Sorry to hear about the AC. I think I would die without it. My Thermostat was reading 109* yesterday.
Check just to the right of the blower. There is a hard aluminum line there that might have been rubbed. It's a tight fit.
Old Apr 21, 2009 | 02:58 PM
Chef-J's Avatar
Chef-J
Booooosstt!!
typical korean.
Hahahhahahah
Come on bro! i had to wake up at 3am in the morning to go my parent's store and been running around to get an insurance quote. ( Koreans are good at excuse too )
Edit: Are you talking about my english? Eh ? Eh? Eh?
Stupid ALLstate..
Old Apr 21, 2009 | 03:04 PM
Chef-J's Avatar
Chef-J
Booooosstt!!
109
I don't know why, when i drove around yesterday. I kept thinking about you. hahahaha
Vortech + Cooling king = istan.
Old Apr 21, 2009 | 03:12 PM
iStan's Avatar
iStan
ZR
Oh, thanks for reminding me, I need to flush my coolant. damnit, I'm lazy=
Old Apr 21, 2009 | 03:42 PM
Nexx's Avatar
Nexx
Old Apr 22, 2009 | 01:05 PM
Chef-J's Avatar
Chef-J
Booooosstt!!
Update, it is leaking from under the blower. Shop telling me I have to take out blower to replace line. He isnot sure if it is upper or lower ones..lol another 300 bucks.
Old Apr 22, 2009 | 01:14 PM
moog's Avatar
moog
Are they charging you to take the blower out? It's pretty easy to remove. You can remove the blower through the wheel well w/o dismounting the plate.. I've done it a couple times.
Old Apr 22, 2009 | 01:49 PM
frankie945's Avatar
frankie945
Heat toasted my ac line but turbo not SC even double heat wraped it.
I think his problem is a rubbing issue. Need the green dye to see exactly where its coming from.
Old Apr 22, 2009 | 01:52 PM
  #38
Chef-J's Avatar
Chef-J
Booooosstt!!
Nah, they not charge me take out blower. Just test leak and replace line and refill
Old Apr 22, 2009 | 01:56 PM
  #39
Chef-J's Avatar
Chef-J
Booooosstt!!
Yep saw green stuff.
But it is really hard to kno untill take out blower or lift it up
Old Apr 23, 2009 | 10:49 AM
  #40
tylerxfire's Avatar
tylerxfire
shitty...good luck chef...makes me think about going to check my work over...no problems yet besides my cat plugging up...but so far so good with the vortech install..knock on wood...
