Another Powerlab GT35R Kit Build in process...
Old Apr 25, 2009 | 09:59 AM
BoostedProbe's Avatar
BoostedProbe
Great start on the build, but I just hate the pipe routing with these kits. That's got to rattle and the heat under the hood has to get up there too. I know with my kit, the exhaust temps get to 1400deg F at WOT. I can't imagine how hot it would get under the hood.
I hope you are doing things in stages. When you go to start the car for the first time if you have problems (and I hope you don't) where do you start trouble shooting? I split my build in half, installed all the turbo stuff, pipes, turbo, IC piping, IC ...ect and then got the car running. After going through everything finding no probelmes, I moved to the Haltech, fuel, wiring, gagues..esct. Jut something to keep in mind I guess.
Good luck with the build.
Old Apr 25, 2009 | 11:39 AM
SlideFox's Avatar
SlideFox
Making progress...
Old Apr 26, 2009 | 03:45 AM
txshldm's Avatar
txshldm
B8BB8B88
looks good!! My setup is 02,02, then wideband on the DP
Old Apr 26, 2009 | 09:13 AM
gotagetmyZ's Avatar
gotagetmyZ
Thanks for posting pics and progress reports. I should start my install hopefully today or tomorrow. I came down with a stomach virus and have been down for the last few days.
Keep the pics and comments coming! I like the heat wrap action you got going. Do you think it made it much more difficult to install because of it? Should I wait to heat wrap after? For better wrapping I'll do it before like you.
DRock
Old Apr 26, 2009 | 07:52 PM
808_enthusiastZ's Avatar
808_enthusiastZ
heat wrapping the pipes makes it a bit more harder to install the kit.
Old Apr 26, 2009 | 10:25 PM
rrmedicx's Avatar
rrmedicx
HEADS-UP!!!
Last Pic on page 1 is very deceptive. It almost looks like the fitting for the oil feed is clocked towards the right fender. That should be more towards the top of the turbo. I remember seeing Jeffie's build and the turbo was clocked at a slight angle tilting to the right, but your photo looks like it is at a complete 90 degree rotated to the right. Can you confirm that the water feeds are on the sides of the turbo and the oil feed is on top before you continue.
Old Apr 27, 2009 | 12:40 AM
ATX350's Avatar
ATX350
Lookin' good so far jamin! Thanks for keeping up with the build pictures, please keep them as detailed as possible for my build in a few weeks!
Old Apr 28, 2009 | 04:57 PM
jaminkid's Avatar
jaminkid
That's not the final position of the turbo. Its in there lose so I can run it to tighten the bolts and install fittings as I go. Will not be in that position as shown in final pic.
Originally Posted by rrmedicx
HEADS-UP!!!
Old Apr 29, 2009 | 08:10 AM
leg killa's Avatar
leg killa
good job man...+1 on keeping us posted..i want that same kit so yeah..you being detailed will be much appreciated
Old May 17, 2009 | 07:33 PM
jaminkid's Avatar
jaminkid
Finally got done. Had few set backs but I pulled through. Enjoyed the experience installing it but it sucks doing it by yourself with only a set of rhino rams and two sissor jacks and a small azz one car garage. I only have pics of the engine as it is impossible to get underneath and take pics. Once I take it to my local mechanic I'll have some pics of the bottom plus a diff cooler kit I installed this weekend too. But being lowered and limit tools to lift the car made the exhaust seemed impossible to bolt up due to lack of leverage. But just had the patience. But getting those clamps take time.
The big set back I had was when I had the up pipes, down pipes, turbo, basically everything in sequence then I broke the big AC line. Tried to kinda move it out the way to clear the downpipe and it just snapped in half. Then waited a lil to get a replacement from Intense.
But...finally got everything done today (all night Saturday). Started on first turn of the key, without even delay. Let it warmed up then I started smelling smoke. Turned out my heat wrapped up pipe was rubbing on the AC compressor belt. So I had to cut that off and adjust the pipe. Other than that no leaks anywhere. However, idle is a little rough. But doesn't shut off unless you blip the trottle a little bit to rev then you have to keep doing it till it eventually starts idling ok. Sounds like I have exhaust leaks. But I tightened and tightened and tightened the clamps (everything is flush and bolted) and sounds a lil better but still noticable. I'll check wastegate clamps and crossover pipe bolts tomorrow. My exhaust needs to be adjusted to fit properly (AAM Single/GT Spec brace). Also smelling a lot of smoke...its not pooring out the exhaust but I can smell the mixture of gas and smoke. Back to work tomorrow. Will do a few more adjustments.... Did the throttle position learning thing and also reset the ECU (got it on the first try). lol
Other than that Im happy everything turned out ok. Just I drive yet...Took me a little longer than I thought but I'll be happy with the results after I get a tune.<p><p><p><p><p><p><p><p><p><p>
Old May 17, 2009 | 10:09 PM
Chef-J's Avatar
Chef-J
Booooosstt!!
^ sweet man!
Old May 17, 2009 | 11:59 PM
Junior_PR's Avatar
Junior_PR
nice bro! happy to see it all done! enjoy!!!
Old May 18, 2009 | 02:58 AM
jaminkid's Avatar
jaminkid
^^thanks
Old May 18, 2009 | 04:04 AM
Ahsmo's Avatar
Ahsmo
Imakecopies
Nothing beats turning the key after a DIY.
Old May 18, 2009 | 04:42 AM
jaminkid's Avatar
jaminkid
I know. It started real quick like nothing happened but just sounds different.
Old May 18, 2009 | 05:10 AM
SoarVigor's Avatar
SoarVigor
Old May 18, 2009 | 06:19 AM
SlideFox's Avatar
SlideFox
Congrats!!!
Old May 18, 2009 | 06:53 AM
  #38
tiguy99's Avatar
tiguy99
Its ALIVE its ALIVE haha
Congrats bro. What's the black box on top of your dash called? Its the one projecting the blue LED #s.
Old May 18, 2009 | 07:25 AM
  #39
jaminkid's Avatar
jaminkid
It's the Defi VSD X. I have it linked with the other Defi gauges and so far it will show speed, rpm, oil p & t, water t, exaust t ect.
Old May 18, 2009 | 07:36 AM
  #40
tiguy99's Avatar
tiguy99
Does it project like a hologram type image on the windshield? It kinda looks like it in your video. I think its pretty cool
