Fuel Injector Latency, or Dead Time, for Various Fuel Injectors
Old Mar 31, 2010 | 09:48 AM
mx594's Avatar
mx594
Originally Posted by binder
from mike:
DW 800cc injector latency
6v to 17v in 1v increments
2.89 6v
2.33 7v
1.96 8v
1.73 9v
1.55 10v
1.41 11v
1.32 12v
1.19 13v
1.11 14v
1.04 15v
0.99 16v
0.94 17v
You aren't using those numbers in Osiris are you? I noticed that you saw my thread about trying to tune with Osiris - I feel your pain.
Old Mar 31, 2010 | 10:40 AM
binder's Avatar
binder
no, I interpulated them for osiris.
Old Mar 31, 2010 | 01:04 PM
mx594's Avatar
mx594
You interpolated them between 10v and 14v or did you do something else?
The reason I say that is because for some reason the values for "stock" latency in the base ROM provided by Uprev are way off from what the actual latency specs are for the stock injectors (as provided by DW). Likewise, the "correct" values for DW 800's in Osiris will not be the same as what you posted above, but instead something significantly lower. Don't ask me why. It doesn't make any sense to me.
Old Mar 31, 2010 | 02:01 PM
binder's Avatar
binder
i interpolated them from the stock latency given by DW.
I don't have to get it perfect since i'm having it tuned this saturday. I just need to get a good base tune to get it up to chicago from st. louis. So far it's idling somewhat ok and it is stoich at highway so i'm ok i think. I'd like to get it best that i can before i go. Furthermore i would like to understand it so i can make changes to it later as things change or if i change something on the car.
Old Sep 11, 2010 | 12:53 PM
binder's Avatar
binder
Originally Posted by Japtrix
Terry you could have just called i would have told you... but since others don't see the need to help people out, i will help out.
HKS says
8V - 2400
10V - 1800
12V - 1400
14V - 1100
16V - 1000
18V - 800
but theres more adjustment for better response. we'll go over it when we retune. we can explain it.
Originally Posted by gmx
this is what I have
HKS 1000CC
Flow LB/Hr 95
Ohm 2
10v 1.31
11v 1.14
12v 1.04
13v 0.97
14v 0.89
15V 0.79
^_^
did we ever figure out which numbers are correct? hks lists the first numbers up top as correct but that's what hal was tuning on my car and i'm still having tons of problems. also my car dips really lean if i load the engine with things like power windows, seats, and a/c so that makes me think the top dead times aren't correct.
Old Sep 12, 2010 | 03:33 AM
midz350's Avatar
midz350
Hal sent me a base map with these #s (I have 1000cc HKS) and Haltech:
9V 1.147
10V 1.092
11V 0.937
120 0.732
14V 0.450
Are they right?
Old Sep 12, 2010 | 10:07 AM
rcdash's Avatar
rcdash
How much does your voltage fluctuate? I notice with those same dead time values, the car goes just slightly rich when the voltage drops (like when running power windows and seats all at the same time). It's very slight for a full voltage point drop, which is fine by me. I am getting a high capacity alternator made from ExtremeAmperage.com to get better voltage at idle when the alternator is hot.
If you switch to dead times that are smaller, you will have even less correction for a voltage drop, which would mean that you would go even leaner...
Old Sep 12, 2010 | 11:02 AM
binder's Avatar
binder
9V 1.147
10V 1.092
11V 0.937
120 0.732
14V 0.450
Are they right?
oh wow, that's so wild because the top numbers i posted were the numbers that hal used for mine which are WAY higher than the ones you use. I wonder why hal would use 2 different values for the same engine. he used the HKS given values for mine and something a lot smaller for yours. weird
If i roll my windows up my car goes lean and bogs. so does that mean i have to increase the dead times? that makes me nervous because i think they are already too high. When i change them, should i adjust them all across the board up and down or only at certain voltages?
Old Sep 12, 2010 | 12:25 PM
midz350's Avatar
midz350
So, should I use this one instead:
HKS 1000CC
Flow LB/Hr 95
Ohm 2
10v 1.31
11v 1.14
12v 1.04
13v 0.97
14v 0.89
15V 0.79
Old Sep 12, 2010 | 03:06 PM
rcdash's Avatar
rcdash
I use the HKS spec (the higher values) and it works fine for me. The numbers you enter only apply for the voltages the ECU sees, so the only thing that really matters is cranking voltage and your running voltage - with all accessories on vs off. If your AFR is steady then you've got it dialed in. Log voltage vs AFR.
Old Sep 12, 2010 | 03:55 PM
midz350's Avatar
midz350
I will use the higher ones and see.
And my AFR isn't steady, so I hope this will help.
Old Sep 12, 2010 | 04:44 PM
binder's Avatar
binder
my a/f fluctuates sometimes but it's usually consistant wth a vacuum fluctuation.
I need to fix the a/f drop when i turn on accessories. When i roll both windows up it'll drop the a/f to 16:1
Old Sep 12, 2010 | 05:14 PM
djamps's Avatar
djamps
In that case you want to bump up the latencies in the <14v areas. Probably focus on 12-13V or use a multimeter to check the exact voltage when you turn everything on.
Old Sep 12, 2010 | 05:33 PM
binder's Avatar
binder
so a larger dead time? dang, that's a huge dead time then. I guess i have no choice.
thanks!
Old Sep 12, 2010 | 05:35 PM
djamps's Avatar
djamps
thanks!
Yea you want more fuel at lower voltages basically... if my memory serves correctly a higher dead time (tuning wise) = more fuel?
Old Sep 12, 2010 | 06:14 PM
binder's Avatar
binder
ya, cause it's open longer. makes sense, mine are just so high already which is crazy.
Old Sep 13, 2010 | 03:57 AM
midz350's Avatar
midz350
I tried the values that is posted here (the higher values) and the car idled better but it bogged like crazy and the AFR was fluctuating (mainly rich).
Will go back to the old values, they were a lot better.
Old Sep 13, 2010 | 08:00 AM
  #38
rcdash's Avatar
rcdash
You cannot just change dead times without retuning your AFR tables. The dead times values are added as the last and final step to the ECU's fueling calculations. It's just a constant add on value... If you increase your dead time by 1.0 (at your running voltage - usually 13v) - you are basically adding 1 ms of fuel to every cell of the fuel table.
Old Sep 13, 2010 | 09:52 AM
  #39
midz350's Avatar
midz350
Is it ok to keep the old ones and finish the engine break in and leave it to the tuner later?
Old Sep 13, 2010 | 10:57 AM
  #40
binder's Avatar
binder
well, that's no big deal to retune some more stuff on the fuel map. If it fixes the lean issue when i turn accessories on then it fixes my problem.
