Need some help pls...
Old May 1, 2009 | 07:11 AM
escobar929's Avatar
escobar929
Default Need some help pls...
So a lil back story about my problem(s)
So roughly 3-4 months ago, I was driving to a meet when all of the sudden the car died, it wouldnt start, it was dead. Luckily a friend of mine (danny = green goblin), lives down the street from where the car died.
So we get to his house and plug it in to a code reader to see what codes it throwing. There were a few codes but the only one that concerned us was a U1000.
Info on U1000 - TSB
http://x.infinitihelp.com/forum/loca...N&pp=12&page=5
So we did everything the TSB said. We also noticed 4 of the coilpacks were melted, the throttle body was shot, the UTEC was also shot and the spark plugs were changed
After all this was done, the car ran fine but not under boost. It would run extremely lean, like 13.3 afr . So we figured it was a UTEC setting that was wrong
So fast forward to now, last night danny and I tried messing w/ the UTEC and we noticed the Parameter map was wrong, so we uploaded the base map from the turbo xs website and we made some minor changes to it
Now since the car had been sitting, the battery was dead, we tried charging it and its still wouldnt start, it would almost sound like it was bout to start but still needed more juice, so we waited a lil longer. After waiting another 15min, we decided the battery was shot, so we went to autozone and got a new battery
Now w/ the new battery, its still wouldnt start. but now we would just get a single click
So we plugged in the cipher to see the voltage the battery had, it was roughly 13.xx but as soon as we would try to start it, it would drop to 7.xx. Then we figured the new battery sat on the shelf for too long and it was low on charge, so we tried jumping it again and still nothing
any thoughts on whats going on?
Old May 1, 2009 | 07:18 AM
Jeremy@Altered's Avatar
Jeremy@Altered
Man Jose, sounds like you have some gremlins in there for sure.
My g35 had the same thing where it was throwing U1000 and burning up coil packs and it ended up being a bad ground on the car. I changed all the grounds and added a REALLY cool grounding kit and it actually fixed it.
Start with the grounds. First you probably need to replace the main fuse that is on the positive terminal on the battery. If you look at it , it is probably blown. That comes from trying to start it with a low battery.
Good luck!!
PS Tell Danny that i still have his moms panties
Old May 1, 2009 | 07:25 AM
GreenGoblin's Avatar
GreenGoblin
Only one correction, The map file is not the turboXS file, it is the orginal map that was backed up off your old utec, I took some screen captures of the parameter files, then setup this new utec accordingly, this is why the map was off. That solves that.
One though well the car has been sitting so maybe the motor is locked up? That is why it is clicking and the starter causes a big draw and that is why we are seeing a big dip in the voltage when trying to crank it over.
We did not try to push start it, I would have like to see if the motor would have at least tried to turn over.
escobar929's Avatar
escobar929
Thats what we originaly did, danny will chime in soon since he did all of that part w/ the grounds
I also installed black bettys grounding kit and was hoping that would solve it, and prevent the u1000 from happening again
we did check the fuse but maybe it was dark out and we couldnt see it
dammit why did who had to move, you could have had the fun of chasing this electrical bug for me
Old May 1, 2009 | 07:29 AM
GreenGoblin
I did not have a test light with me, but all the main fuse and relays appeared to me good (I know that is not set in stone) I did clean with a wire brush all the grounds that it described in the TSB.
Tibbs your mom goes to college.
Old May 1, 2009 | 09:24 AM
str8dum1's Avatar
str8dum1
if you are dropping to 7V, you have a serious ground problem or a short somewhere. double check all of that.
for the voltage to drop that much it would be like trying to shove watermelon sized current thru a straw.
Old May 1, 2009 | 09:34 AM
escobar929's Avatar
escobar929
could it be that the starter is shot and sucking all the power?
Old May 1, 2009 | 10:14 AM
GreenGoblin
I agree, but do you think that would happen if the motor was siezed, not allowing the starter to turn the flywheel?
Old May 1, 2009 | 03:26 PM
superchargedg's Avatar
superchargedg
Damn Noobs
It sounds like the starter has bit the dust as you said it gives one click and thats it.
Old May 2, 2009 | 04:54 PM
__jb's Avatar
__jb
Z + Rear Seat
Jeepers, that's some bad luck, Jose...
If you think it seized, try draining the oil. Obviously if you see a lot of metal flakes that would be bad.
What kind of noise did it make when it died on the way to the meet? Did it feel like the engine was binding up, or did it feel like the electrical side just gave way and coast to the side of the road?
Old May 3, 2009 | 04:12 AM
escobar929's Avatar
escobar929
^it was def electrical
after we switched the coil packs, utec, TB, and the plugs the car ran perfectly but just out of boost
Old May 3, 2009 | 09:22 AM
__jb's Avatar
__jb
Z + Rear Seat
Might be worth a call to TurboXS...
Might be time to ditch the UTEC and go with an Osiris tune...
Old May 3, 2009 | 12:19 PM
escobar929's Avatar
escobar929
the reason for that is cause the Parameter file was wrong, and we tried starting the car w. just the oem ecu and still nothing
Old May 3, 2009 | 12:41 PM
XKR's Avatar
XKR
I am thinking Starter also.... Try push starting the car...if it still wont start....well...rule out starter.
Old May 4, 2009 | 04:55 AM
GreenGoblin
Mike that was next on my list to try to push start it, but It was late and I would rather have an extra set of hands to help push.
Old May 4, 2009 | 05:22 AM
Jeremy@Altered
Danny, your mom has really good hands, maybe she should help out.
Old May 4, 2009 | 07:18 AM
GreenGoblin
^ This guy
Old May 5, 2009 | 07:08 AM
JZurita's Avatar
JZurita
I'm having similar issues right now with my car. It all started two weeks ago and day by day it keeps getting worse.
Day 1:
Radio wouldn't turn on; had to replace a blown fuse
Day 2:
HKS EVC6 boost controller won't turn on
A few days later:
Car can't idle without shutting off.
Later that same say:
Car has a tough time starting. I hear the starter, but the car doesn't crank. Eventually it cranks after three tries.
Same day, after finally getting the Z to start:
Car wouldn't boost… f*ck…I drove the car home, parked it, tried starting it an hour later and now it doesn’t start at all… I hear the starter, but it's not catching the flywheel…
So basically at this point my HKS EVC6 doesn't turn on, the car doesn't boost, and now it won't even start...
WTF IS GOING ON!?
Old May 5, 2009 | 07:25 AM
JZurita's Avatar
JZurita
* OP, I don't mean to thread jack or anything. I just saw that you're having similar issues as me and needed to say something out of frustration.
I think I'll start another thread in a few.
Old May 5, 2009 | 10:44 AM
Cass007's Avatar
Cass007
Update? Did you figure out what the issue was yet?
