Runs RICH after awhile of driving...
Old May 4, 2009 | 03:00 PM
Zphanatic's Avatar
Zphanatic
So O2 sensors seem to be it? No other possibilities?
Old May 4, 2009 | 03:18 PM
doug's Avatar
doug
no one is going to pin point what the specific problem is.. you can either keep swapping sensors till you find the problem.. or you can bring the car back to where you had the work done for them to look it over.. the choice is yours.. but we can play this roulette game all day long
Old May 5, 2009 | 03:05 PM
Zphanatic's Avatar
Zphanatic
True, but money is not allowing that right now... So I am trying to fix it myself.
So the upstream O2 sensors (on the manifold) are the only ones that adjust themselves? Can the rear (downstream, on my test pipes) O2 sensors do the same as well?
Old May 5, 2009 | 03:26 PM
doug's Avatar
doug
no.. they just tell the ECU if you have cats there or not.. they don't do any adjustment at all..
but now that i think about it.. the front O2's are only suppose to start reading after the car is warm.. so the car wouldn't be reading rich when cold
Old May 5, 2009 | 04:47 PM
Zphanatic's Avatar
Zphanatic
It only read rich the one morning I went to work. Besides that, everytime after driving it within 15-20 min it would starting reading rich.
Any other thoughts?
Old May 5, 2009 | 04:50 PM
doug's Avatar
doug
so when you start it up cold.. what does the A/F read? if its ok... then once the car is warm it goes to 10.. that would indicate the Front 02 Sensors
Old May 5, 2009 | 04:55 PM
Zphanatic's Avatar
Zphanatic
Yes, besides that one morning, its always been after driving it within 15-20 min. And when it is already warm, lets say I drove it for a bit already, and I get back into the car within an hour or so, it starts off rich again
Well, now I gotta save for some expensive sensors. LOL!
Old May 5, 2009 | 04:58 PM
doug's Avatar
doug
what about the OP? doesn't he have a Z? maybe you can swap his sensors just to make sure thats the problem before you waste money chasing problems you don't have
Old May 5, 2009 | 05:09 PM
Chef-J's Avatar
Chef-J
Booooosstt!!
So problem was sensor? Or what
Old May 5, 2009 | 05:12 PM
Zphanatic's Avatar
Zphanatic
Not sure yet, but we are gonna try putting in some different sensors, and hopefully that does the trick. I hope it works...
I would just imagine, the Check Engine Light would come on, telling me they are bad? Right? Or maybe thats not it? I am gonna shoot for it anyway...
Old May 5, 2009 | 05:16 PM
Zphanatic's Avatar
Zphanatic
He has an HR, so it wouldnt work. I will ask a couple other buddies I know...
doug's Avatar
doug
since the ECU is controlling the car.. its definately a sensor.. i guess the ECU doesn't see it as a real fault to trigger the CEL as yet
Old May 5, 2009 | 05:27 PM
Zphanatic's Avatar
Zphanatic
Sounds good, I am gonna try it tomorrow...
Old May 5, 2009 | 05:38 PM
Zphanatic's Avatar
Zphanatic
One more quick question... Does it really take the sensors that long to heat up? About 15-20 min? Any, I actually drove it all day yesterday and did it once all day. Which is weird as well.
Old May 5, 2009 | 05:53 PM
rcdash's Avatar
rcdash
change plugs (sorry if you already tried this), but misfires will cause you to run rich, because well, the fuel doesn't burn. It's either that, O2 sensor (but both banks rich?), the UTEC (i've had it hold injectors on one bank wide open!), or the injectors.
Old May 5, 2009 | 06:24 PM
weslutes's Avatar
weslutes
Originally Posted by Jeremy@Altered
o2 sensors on yours too. Probably actually air flow meters used in the late 04s and up. They tend to go lean, then correct themselves, then go lean, then correct themselves, ect.
The o2 sensors actually can correct 25% all the time, plus another 25% on top of that if needed. So they can cause it to run really rich or really lean.
Thanks. That is exactly what mine is doing. Runs great at WOT, bad at idle every other minute.
I used to have the m/s misfire when I had the NGK coppers, switch back to Iridium & no codes now
It only happens when my motor is warm...
Totally sounds like the o2 sensors. I have a spare set, just not enough time to install.
Old May 5, 2009 | 06:50 PM
Zphanatic's Avatar
Zphanatic
Well, plugs are only a month old, injectors probably like 2 months old, lol, but Utec is a couple years old (like 5 maybe) I will try the O2 sensors, and see what happens.... which I rather have them be the problem, instead of Utec.
Old May 5, 2009 | 07:01 PM
  #38
rcdash's Avatar
rcdash
Oops - sorry I missed that part. What kind of plugs did you replace with? Could still be the cause... That you noticed the P0300 right when it runs rich is a good clue.
Old May 5, 2009 | 08:05 PM
  #39
Zphanatic's Avatar
Zphanatic
I think that code was just a coincidence that one day. cause it has not come back and it still runs rich. I have one step colder plugs, NGK.
Old May 5, 2009 | 08:23 PM
  #40
Chef-J's Avatar
Chef-J
Booooosstt!!
Why not check with where you got tune? Isn't that much easier? I'm sure shop will not charge you if you come back to check your A/F issue.
