Spark plug tip and electrode touching!!! ???
Old May 3, 2009 | 06:32 PM
350 Rookie's Avatar
350 Rookie
Default Spark plug tip and electrode touching!!! ???
So i have a customer with a 2000 nissan sentra. Every now and then he gets his plug in cyl 1 and 4 spark plug electrode thing pushed down to the tip. However, i dont think the piston is touching it because i looked down the hole, i do not see any marks on the piston and also, on the perimeter edge of the plug, it looks beaten up. What can cause this to the plug? Detonation? I checked the part number on the plug, its the correct one.
Can someone help me out please. thanx
Old May 3, 2009 | 06:45 PM
thom000001's Avatar
thom000001
If it were detonation, the electrode or grounding strap would start to be consumed.
Only thing I know of that would cause this is contact.
Sure plugs are correct length?
tom
Old May 3, 2009 | 07:35 PM
TrackPack's Avatar
TrackPack
smashed rod bearing can cause contact, but you would hear it first in the bottom end lol
Old May 3, 2009 | 08:29 PM
350 Rookie's Avatar
350 Rookie
So where do i even start with this. I never dealt with a car like this so idk what to check first. and lets say the rod bearings were bad. In that case, it would happen all the time. This only happens under load. When the car is idling, the plugs are fine, but when you drive, the 1st and 4th plugs get smashed in. I dont understand.
and the plugs are the same length as oem.
Old May 4, 2009 | 04:48 AM
Jeremy@Altered's Avatar
Jeremy@Altered
You wouldnt see a mark on the piston because it would be covered with black soot almost immediately. I would say its the piston hitting it though.
Old May 4, 2009 | 10:52 AM
ADMAN's Avatar
ADMAN
on piston hitting. Or, plug was tightened down too hard. Still have a washer on it?
Old May 5, 2009 | 05:09 AM
350 Rookie's Avatar
350 Rookie
Ya the washer is still on it. SHould i put another washer to space it out a little more or would that harm anything?
burglapfd
Dec 6, 2020 01:04 PM
350z82
Oct 1, 2015 06:25 PM
35reilly
Sep 28, 2015 07:42 AM
