running low boost with Vortech
Old May 9, 2009 | 10:59 AM
Torched Z's Avatar
Torched Z
Default running low boost with Vortech
ok so heres the jist of it. my car has been sitting for almost two years getting some body/paint work done. I just drove the car for the first time a few months ago and again today. i put my boost gauge in and ran the car and only saw 4lbs of boost...... Vortechs website says i should get like 7-8psi. Just wondering what it could be. Loose belts? Bad fuel? Airflow? Leak? Gauge? the car is still not completed so i cant test and tune it daily. just wondering if anyone knows what the problem could be?
many thanks in advance
Old May 9, 2009 | 11:28 AM
str8dum1's Avatar
str8dum1
it could be any one of those things that you mentioned.
boost leaks require detective work that cant be done over the internet.
Old May 9, 2009 | 11:34 AM
Nexx's Avatar
Nexx
its either a leak or belts slipping, bad fuel doesnt determine how fast your blower spins and boosts.
Old May 9, 2009 | 12:08 PM
Chef-J's Avatar
Chef-J
Booooosstt!!
Humm try Push more harder.
Edit: What size ur exhaust? And running header? Tp?
Old May 9, 2009 | 01:47 PM
Torched Z's Avatar
Torched Z
yea on my grand prix i did headers and it lowered the boost but i dont have that for this car. just the nismo catback exhaust and high flow cats. Now i messed with the cog belt cause it was really loose and someone who i work with said that could be it. Tightened it but got nothing. another day ill try another gauge. the one i have is a defi....
im going to end up getting a smaller pulley(3.12) and cog(34tooth) but i want to see whats wrong before i do that.
Old May 9, 2009 | 02:04 PM
str8dum1's Avatar
str8dum1
so you have a non-revup with a 3.33 pulley?
you arent going to get 7-8 psi with that. maybe 5. i doubt you have anything wrong.
Old May 9, 2009 | 03:40 PM
350Z400rwhp's Avatar
350Z400rwhp
Do a boost pressure test and make sure your belt is tight and let us know.
Old May 9, 2009 | 05:21 PM
Torched Z's Avatar
Torched Z
Vortech I thought said u get 7psi out of the box? I'll do the test as soon as I can.
Old May 11, 2009 | 06:37 PM
Torched Z's Avatar
Torched Z
does the supercharger have a wastegate? if so what if its not allowing more then 4psi? is that even possible?
Old May 11, 2009 | 07:58 PM
str8dum1's Avatar
str8dum1
no thats not possible.
i dont think anyone knows when/if the bpv releases overboost. You'd have to run straight from the blower to the TB to even get high enough pressure to test (ie >17 psi)
plus you could hear it if it was leaking.
Old May 12, 2009 | 05:33 AM
Car vs. Driver's Avatar
Car vs. Driver
You're very likely to be running less boost because of your exhaust. Once you free up the exhaust with an SC setup, your boost pressure will decrease, yet you can make more power.
That's probably not the whole reason, because 4PSI is unusually low. You have something else going on as well.
The BPV that comes with the kit does not release pressure for over boost - the point of a BPV is to hold closed under boost, never to release until the MAP goes into vacume.
Old May 12, 2009 | 06:41 AM
Vas@Extended's Avatar
Vas@Extended
Vendor - Former Vendor
Iam running the 2.87 and iam only seeing 5psi... I gotta check my belts and do a boost leak test. It was definitely running higher when I first got it tuned. It felt stronger too.
I dont think the nismo exhaust can lower the psi by that much. Can it? I have the nismo exhaust and testpipes.. I did 415/370rwtq
Old May 12, 2009 | 08:10 AM
jpc350's Avatar
jpc350
What was your boost pressure at these #'s?
Old May 12, 2009 | 09:16 AM
dikspiel's Avatar
dikspiel
Chestons Toilet
i want to see what 2 years worth of bodywork/paint looks like
Old May 12, 2009 | 09:17 AM
Car vs. Driver
Wow .. Vas, you have some issues then. I'm hitting 11PSI peak with my 2.87 setup, including exhaust, headers and test pipes.
With those numbers you have to be around 10-11PSI range when you got tuned. Check your belt tension, it stretches and subsequently loosens over time and needs to be checked every few weeks.
Old May 12, 2009 | 10:28 AM
str8dum1's Avatar
str8dum1
if it was slipping that bad, it would squeal like a pig at startup!
Old May 12, 2009 | 11:39 AM
Chef-J's Avatar
Chef-J
Booooosstt!!
Don't u have gtm pulley? Humm 5psi is very low with 2.87. I feel like you have a boost leak. What size belt you running?
Edit: btw your exhaust is fine. I have 2.5 td with 3.12 pulley. And hitting up till 7-8 psi if I push hard.
Old May 12, 2009 | 11:58 AM
Vas@Extended
I know its either sliping or leaking somewhere. because the first day I got it.. it was like holly hell. I would break loose in top of 3rd. Now I get full traction in 2nd lol. I mean its still fast as hell than NA and its kinda fun at the same time to be able to hook it up. but I do miss the pull .
5 psi is deff low. Iam going to remove the belts and clean them with rubbing alcohol n test it like that. if no luck, iam going to do a boost leak test next
Old May 12, 2009 | 12:00 PM
Lawy'dU's Avatar
Lawy'dU
It definitely sounds like a belt issue, but yes, headers and highflow cats/test pipes will decrease boost on the vortech.
Old May 12, 2009 | 12:05 PM
Vas@Extended
Originally Posted by Chef-J
Don't u have gtm ? Humm 5psi is very low with 2.87. I you have a leak. What size belt you running?
Edit: your is fine. I have 2.5 td with 3.12 . And hitting up till 7-8 if I push hard.
chef,
Yes I do!. There is a little oil coming from the back of it and also some in top of my hood. So my seals are going bad. and there is some mist in the back of the blower where the cog is. Iam also 90% sure its that, thats making it slip. Iam going to keep it like this for just another week untill I sent it for the 65K rebuild .
as far as belt size iam not sure. I have tried a whole bunch untill it was the right one. The pulley belt is fine and its strong as hell. the cog belt in other hand lol
