Turbo Xs Map sensor install
Old May 31, 2009 | 07:52 PM
brandonphil's Avatar
brandonphil
Default Turbo Xs Map sensor install
I was wondering where to hook up the hose side of the turbo xs map sensor? Do I just T- it into a vacuum line? Thanks
Old Jun 1, 2009 | 03:31 PM
psychoballistic's Avatar
psychoballistic
Yes but it has to be after the throttle body. Theres a port off of the plenum you can use a T with other lines, or you could tap a new port. I just use a T.
Old Jun 1, 2009 | 05:48 PM
350 Rookie's Avatar
350 Rookie
Im about to install mine too exccept the plenum port in the front, i got 2 tees already on that. can i put a third T. LOL
Old Jun 1, 2009 | 06:17 PM
Glex25's Avatar
Glex25
You can put a third or you can use the vacuum source by the throttle body that also feed the brake line booster.
Old Jun 2, 2009 | 08:35 AM
psychoballistic
You'll be fine using a third T, it might be easier though and a cleaner install with a 5-way T or one with enough ports on it for everything you might need vacumn/boost lines for.
Old Jun 2, 2009 | 08:44 AM
350 Rookie's Avatar
350 Rookie
Well i have my T's in series and not parrellel if you are into electrical wiring and know what i mean. It already looks clean and not messy. i guess, ill add another.
Old Jun 2, 2009 | 08:47 AM
psychoballistic
I think I get what your saying, in which case I would keep it the way your going, ultimately its personal preference, but you'll be fine either.
Old Jun 2, 2009 | 08:49 AM
350 Rookie's Avatar
350 Rookie
ok thanx.
Old Jun 2, 2009 | 10:07 AM
Vas@Extended's Avatar
Vas@Extended
Vendor - Former Vendor
I have my BPV, map sensor and boost gauge in the plenum. You should be fine.
Old Jun 2, 2009 | 02:16 PM
brandonphil
I decided that I already had my boost line ran into the car so I used that line and then t-ed it in the car since the map sensor wires will be running in the car anyway... Thanks for all your help!!!
2ndchanceZ
Oct 26, 2015 08:03 PM
