Alittle Help Vortech Fuel & Vacuum Help
Old Jun 13, 2009 | 06:35 PM
shiftdrift06's Avatar
shiftdrift06
Default Alittle Help Vortech Fuel & Vacuum Help
Ok, I am al ittle unsure if I routed my fuel lines right, just making sure before I continued. Does everything look correct? Also, I marked two lines red and blue and I am assuming they connect to the lines in the other picture.
Also how do you take the stock fuel line off? Its on there good!!
My Vacuum Set up, Is it correct?
Old Jun 13, 2009 | 07:01 PM
binder's Avatar
binder
just a quick look at the bypass valve vacuum that looks correct.
the fuel line is a hard type plastic line. I had to cut mine to get it off. Then i went all the way back to the connector on the side of the car body (passenger side) and took the fuel line off of it. Hook the new fuel line to the connector and ran it to the fuel management.
you're red hose in the picture (goes directly to the middle of the FMU) is what goes to the line back to the fuel pump. The blue one goes up to the engine on the damper you have on the other picture.
jeffbinder@gmail.com
email me if you have any further questions. I might not get on here in time to answer your question quickly.
Old Jun 13, 2009 | 10:45 PM
shiftdrift06
OHh so do I just have the lines reversed?
I am not very fond of the Vortech diagram
Old Jun 14, 2009 | 04:55 AM
binder's Avatar
binder
ya, switch them on the FMU and you should be fine.
I didn't use the stock line at all. If you choose to use it keep them connected with the same circle colors you have like that, just switch the lines on the FMU and it should be just fine.
The middle line on the FMU (directly in the center) should come from the fuel tank.
