sleeved engine nightmares
Old Jun 19, 2009 | 05:53 PM
carlosG's Avatar
carlosG
Originally Posted by SlideFox
What type of numbers are you trying to achieve?
Sleeves and the VQ haven't had the best history so far....
I had 615 rwhp on my previous set-up at 13 pounds of boost I hope to get a minimum of 725 rwhp I ran the car 3 years ago and was able to run a 11.3 on the 1/4. I still want to be the first g35 to run a 10 sec on the 1/4.
Old Jun 19, 2009 | 05:55 PM
carlosG's Avatar
carlosG
Originally Posted by thom000001
who machined your block and installed your sleeves?
I sent my bolck to Forged Performance for the sleeves
Old Jun 19, 2009 | 06:00 PM
carlosG's Avatar
carlosG
Originally Posted by Z1 Performance
who installed the sleeves? the install is the critical part
assuming you've tried running it without a thermostat, or trying a new thermostat?
have you purged the heater core?
how long has the engine been in the car? at what boost levels? details?
The car has the thermostat housing, the car only has 50 miles of break-in at low boost. I did purged the system, but do you have to do a separate purge for the heater?
Old Jun 19, 2009 | 09:52 PM
thom000001's Avatar
thom000001
Well, now we have shown that 800rwhp is no problem on stock sleeves....matter of fact, 900rwhp doesn't seem out of the question either...we shall see....
so unless you are looking for 1xxxrwhp....and deeeeeeep into the single digits in the 1/4 with crazy (like 150+mph)...then stock sleeves are probably fine.
tom
Old Jun 20, 2009 | 03:27 AM
SmallTuner's Avatar
SmallTuner
i dont have any problems with my sleeves .
but in summer the temp is a bit higher, this is normal in the arabian gulf.
Old Jun 20, 2009 | 05:55 AM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
tom
I think that statement should be qualified a bit. I would not go so far to say that a couple of engines that have done it necessarily means it's fine. Time is the great equalizer of these types of things as age and mileage can have interesting effects on things. Definitely a good thing to see more people push the limits - it's how everyone else can learn.
Let's not forget too that some engine configurations will require the use of an aftermarket sleeve. I do agree though that they may have been overpresribed in the early days, but that is a compound issue. There are far too many assemblers out there, and far too few builders. This is a problem every community has, and I think, especially this one. I have never been in a community where people are subject to building their 2nd, 3rd, 4th built engine that is nothing more than a street car (despite what tales of fiction they or their shop might lead them to believe) and others are on their 1st. The second thing is time. Engines need time in the hands of truly experienced people, with the time and money to experiment to see where the boundries truly lay. Time is the great equalizer. When an engine is new, the common trend of your average shop, and your average consumer, is to toss everything and the kitchen sink at it, all in the name of reliability. This is a community that seems to reward the mod list in the signature, rather than the process by which a truly successful build is achieved. A community that thinks researching to death the internet-fed nuances of one forged $200 piston vs another is suddenly going to mean rousing success or imminent failure, yet doesn't spend nearly that amount of time researching who is clearancing their block for said pistons. There are plenty of people who had all the best stuff money could buy, and ignored, or took for granted, the most important ingredient of all.
To the OP - start with the simple stuff first. For example
Does the heater inside the car work? Does it blow hot air or does it not warm up?
Are there noticeable differences in temperature between your upper and lower radiator hoses?
Old Jun 21, 2009 | 07:37 PM
thom000001's Avatar
thom000001
Very true, thats why I picked a shop that has done many higher hp builds than my car could ever hope to attain.
tom
Old Jun 22, 2009 | 12:09 AM
Cass007's Avatar
Cass007
So the proper technique is what? I have heard of at least two different methods.
Old Jun 22, 2009 | 03:07 PM
superchargedg's Avatar
superchargedg
Damn Noobs
Excellent post.
Old Feb 3, 2011 | 12:56 PM
2fasst's Avatar
2fasst
Hal, are you still sending your blocks to be sleeved by Darton West Coast or are they all done in house now?
Originally Posted by Hal@Dynosty
I disagree entirely about sending to Darton, unless you are referring to Darton West Coast. I don't know if their east coast install facility (ERL) has corrected their practice of Darton sleeve installation but we had two out of two VQ failures when we gave them a chance two years ago. After speaking with Darton they said West coast and East coast use two different finishing methods. Since that time ERL has asked multiple times to regain our business, but I will not send another block there and take another chance with them due to the time and money involved with fixing any mistakes/problems. Our current machine shop (now moving in house) has never let us down including many daily driven sleeved VQs to our drag car at 1000+whp.
It is sad to hear the bandwagon against sleeves which came about after a number of sleeve failures which I feel confident were due to faulty installation/builds and not the sleeves. For anyone under 500 or 600 horsepower I don't see any problem going unsleeved, but above that for any period of time is still uncharted territory and taking an expensive risk. Even Intense Power, who holds the unsleeved horsepower record, only uses "roughly 600whp" on the street/track and says,
"You know that Han's widebody G doesn't have a sleeved motor. While it can achieve 900+whp on a non-load based dyno such as a DJ, it would be foolish to run the car at that power level while under load on the track and expect the stock sleeves to withstand repeated 1/4 mile passes."
Old Feb 3, 2011 | 02:11 PM
Cass007's Avatar
Cass007
Hal, was Darton East the same as Justice Racing back in the day? I know I have seen logos on their door at the shop.
Old Feb 3, 2011 | 02:43 PM
Dynosty's Avatar
Dynosty
Vendor - Former Vendor
^ from experience, I would highly recommend our in-house sleeving package. PM sent.
Old Feb 3, 2011 | 07:36 PM
Sylvan Lake V35's Avatar
Sylvan Lake V35
Send it to Darton West coast or Injected , i am going to have my block decked and give it one more try before the block and maybe the whole car end up at the bottom of Sylvan Lake
Originally Posted by westpak
Unfortunately only remedy is to disassemble back to bare block have them make sure the sleeves are down and redeck the block and hope you have enough left in the block or you will then have issues with the rear timing case not lining up with the heads properly, I barely made it when I rebuilt it after that.
Also make sure they open up the cooling hole that is partially blocked now by the sleeve, my machine shop missed that the first time and I am amazed the coolant made it into the block
Did this solve your issues? I am going to have to check out the cooling path that is blocked...where is it at the bottom of the sleeve? I never noticed one blocked when i was looking over things the other night but i can't deal with another f*@k up so i am going to have to go over things again. Did you run a thick head gasket? Do you know what thickness you ran I am nervous about things not lining up after it gets decked.
Old Feb 3, 2011 | 08:21 PM
eltness350's Avatar
eltness350
The Untouchable
i had gtm sleeve my block...it cracked on forged's dyno no sleevies for me now pure powa only
Old Feb 4, 2011 | 05:08 AM
djamps's Avatar
djamps
Uggh... I really agree with some of the statements here... sleeve problems (as well as many other premature failures) seem like assembly issues, not inherent problems with sleeves. Hell even non-sleeved blocks have issues (cass, anyone?)
which really freaks me out given that a lot of 'big name' companies can't seem to get it right... who the hell to trust?? Makes me want to get another stock engine if it ever blows...
Old Feb 4, 2011 | 05:16 AM
Alberto's Avatar
Alberto
Cranky FI Owner
I straight up dont trust anybody on a VQ to sleeve properly. My second motor seemed fine, then suddenly even with the Evans + pressureless system it started overflowing coolant to the top of the overflor just on turning on the car!
For a drag car, or shop car whatever, for a customer's STREET car no sleeves would hold up to my driving.
My evidence
Attached Thumbnails sleeved engine nightmares-coolant-poster.jpg   sleeved engine nightmares-gtm-drain-plug-poster.jpg
Old Feb 4, 2011 | 05:20 AM
djamps's Avatar
djamps
My evidence
Cass going on his 5th, you going on your 3rd
Old Feb 4, 2011 | 05:37 AM
  #38
Alberto's Avatar
Alberto
Cranky FI Owner
Mid-A region has the potential to easily have the most built VQ's but funny thing is 90% of the time they are never running
Old Feb 4, 2011 | 05:46 AM
  #39
rh_334's Avatar
rh_334
My evidence
Old Feb 4, 2011 | 09:09 AM
  #40
InjectedPerf's Avatar
InjectedPerf
Injected Performance
Darton East is now Justice Racing, was a ERL a year or so ago. I would not recommend Justice Racing or ERL. We have seen issues with both companies and found flaws in both of their work.
