Issue with vortech belts Goodyear VS Gates
Old Jul 20, 2009 | 10:21 AM
  #41
350z006's Avatar
350z006
gates #k060930 for revup 2.87...
Here's one for super cheap on ebay...I bought a few from him...
http://cgi.ebay.com/ebaymotors/GATES...lenotsupported
Originally Posted by Larry@Showtime
^ Thank you.. but still not sure what belt size to get for 2.87 revup.
Old Jul 20, 2009 | 10:56 AM
  #42
Fleet Z's Avatar
Fleet Z
With the 3.12 RevUp, you can use the 93.5" or 93" belt. I have the Goodyear Gatorback 93.5" on currently. With the 2.87 pulley, I would think 93" or less....
Old Jul 23, 2009 | 08:06 PM
  #43
Torched Z's Avatar
Torched Z
ok so with the non rev-up and a 2.87 what size belt do i need?
Old Jul 23, 2009 | 08:23 PM
  #44
binder's Avatar
binder
well the 93" they are talking about is for the old style belt routing.
do you have the new or the old belt routing? The new belt routing has 2 idler pullies on the vortech mounting plate. The old routing has 3 idler pullies mounted to the plate.
If you have the old design I have a stock gaterback belt that my vortech came with but then i switched to a different belt routing and had to go to an 80 1/8" belt.
It has probably 200 miles on the belt. PM me if that is the belt routing you have cause i need to get rid of this belt from my garage.
Old Jul 24, 2009 | 04:12 PM
  #45
Torched Z's Avatar
Torched Z
well i just bought the GTM pulley and Belt kit last night.....so what routing will that be now? Three? heres a pic not sure if its good enough[IMG] [/IMG]
Old Jul 24, 2009 | 07:49 PM
  #46
binder's Avatar
binder
that's the stock routing that uses a 93" belt.
Old Jul 24, 2009 | 07:56 PM
  #47
binder's Avatar
binder
this is the stock setup you have there in that picture you uploaded.
this is the new routing for non-rev up motors. It will work with the plate you have now you just have to move some pulley's around. It will require and 80 1/8" belt. It helps belt slip.
Don't worry about belt slip if you have the gtm pulley mod with the stock belt layout. GTM pulley will pretty much eliminate any slip. You're good to go.
Old Jul 24, 2009 | 10:46 PM
  #48
tylerxfire's Avatar
tylerxfire
op are u having problems with the belt rubbing the crank case cover on the front or anything rubbing the hood with the gtm pulley mod? i am not sure where to place it on the bracket and dont wanna mess it up...also what did u do just drill it out for the bolt to pass through?
Old Jul 25, 2009 | 03:20 AM
  #49
Chef-J's Avatar
Chef-J
Booooosstt!!
Tyler,
I'm using my phone, so can not bring a photo uphere. But do you remember the photo I took it for you from other my thread? Check that out, if you install them just little bit lower than mine, I think you can avoid the rubbing hood. Or you can try install it at under, hard to explain without photo, but you know how some people installed two GTM pulley? One install at where I installed or op, and other pulley goes bottom of that pulley. You can try just install at where second pulley goes.
If you confuse let me know, I can post pic for you tonite.
Old Jul 25, 2009 | 05:44 AM
  #50
Torched Z's Avatar
Torched Z
yea can you post up some pics for me please! Not sure where i need to put the pulley at when it comes. and the belt it comes with will work with a 2.87?
Old Jul 25, 2009 | 07:17 AM
  #51
Chef-J's Avatar
Chef-J
Booooosstt!!
First, you have to contact with GTM, tell them you are going to run newer setup with 2.87 pulley. So they can send you right belt. GTM sent me a older setup belt when I ordered. I forgot to tell them, its for newer setup.
Newer setup, some people running 80 1/8 or 79.xx with GTM pulley or some could use same belt after installed GTM pulley.
Pictures, I posted on my other thread. If I can get to computer I can post it for you. But its faster if you go look. Think was in when chris tuned thread. Also if you look sentry's vortech thread that has some layout, that will help you where to install pulley and set belt.
I do remember there is DIY thread on g35driver...I do remember saw them, but not sure was on G forum.
Old Jul 26, 2009 | 04:22 PM
  #52
binder's Avatar
binder
on my g35 i have problems with the belt touching the timing cover in the front. I grinded it down as much as i thought i could and be safe. It has space when the motor is off, but i can see some black residue where the belt has hit the front of the cover while i'm driving it. I would assume from the belt flexing some and moving a little bit.
Old Jul 26, 2009 | 05:32 PM
  #53
Chef-J's Avatar
Chef-J
Booooosstt!!
Mine as well. Glad that we used cheap belt at first, it grinded enough cover now it has enough room. Just a first belt grinded it and no problem.
350Z_Al
Oct 29, 2020 07:44 PM
Fixxxercask
Nov 9, 2015 11:10 AM
350z82
Oct 1, 2015 06:25 PM
