100k+ turbo install
Old Jun 27, 2009 | 10:34 PM
erichsherrill's Avatar
erichsherrill
Default 100k+ turbo install
i just read the thread about fi on stock motors and its scarin the crap out of me. i am about to do an install of a TN ST. i have 110k on my car does anyone have any suggestions how i can do this safely (max psi ect.) has anyone else done this? 75% of these miles are highway comuter miles but none the less. thanks for any help!
Old Jun 27, 2009 | 10:50 PM
SchismX's Avatar
SchismX
If it scares the crap out of you, then get a built motor. I wouldn't suggest throwing FI on a stock motor with 110K miles anyway.
Old Jun 27, 2009 | 11:09 PM
Chef-J's Avatar
Chef-J
Booooosstt!!
+1, i would think about build motor at that milies. But if you want do turbo, compression test is good option as well.
Old Jun 28, 2009 | 01:50 AM
Armitage's Avatar
Armitage
At the least get a compression check and depending on those results, a leakdown test. However, if you have any kind of weakness in any of your cylinders, you can assume FI will speed up that failure and it will blow at some opint.
Old Jun 28, 2009 | 05:49 AM
Cass007's Avatar
Cass007
3 F/I THREADS STARTED WITH YOUR FIRST 3 POSTS?!?!?!?!?
BTW - this topic has already been addressed.... SEARCH!!!
Old Jun 28, 2009 | 08:36 AM
failsafe306's Avatar
failsafe306
SLAPDOWN!!!
Old Jun 28, 2009 | 08:58 AM
Driver06's Avatar
Driver06
I thought he was talking about spending 100k on his setup
Old Jun 28, 2009 | 10:07 AM
erichsherrill
im sorry im new to this. around how much would a compression test be?
Old Jun 28, 2009 | 11:36 AM
Madelinot's Avatar
Madelinot
LOL! If you're asking how much a compression test is, you're NOT ready for forced induction....
Old Jun 28, 2009 | 11:40 AM
quakerroatmeal's Avatar
quakerroatmeal
Indeed. A lot of people would say it's the perfect time for boost, and if it blows = BUILT.
Old Jun 28, 2009 | 02:30 PM
superchargedg's Avatar
superchargedg
Damn Noobs
You may be new to this but we all were at sometime and we used the.....(drumroll)
the friggen search button.
Old Jun 28, 2009 | 05:36 PM
erichsherrill
appologizze!! search button found..
Old Jun 29, 2009 | 09:36 AM
tiguy99's Avatar
tiguy99
Wow I almost thought the thread was about a 100K FI install
I almost went
Old Jun 29, 2009 | 10:04 AM
SirSpeedyZ's Avatar
SirSpeedyZ
sounds dumb
Old Jun 29, 2009 | 10:42 AM
Jason333's Avatar
Jason333
hi
I almost went
There is /was a guy on here with over 100k miles on a Greddy kit. He built his motor at like 130k miles.
Old Jun 29, 2009 | 01:50 PM
Sharif@Forged's Avatar
Sharif@Forged
Forged Performance
100k miles is nor an issue, as long as the engine is sound and well maintained. We've done FI on stock blocks at or near 100K...none have failed.
Old Jun 29, 2009 | 05:42 PM
erichsherrill
yes it is very well maintained all oil changes on time. not too hard driven. i am in the air force and live just under 200 miles from home. my first 2 years of having this car that trip was made almost every weekend. so majority of this was highway miles. the car runs great right now ive never had any issues with it. i appreciate the info from you guys. alot of you sure do express your opinion straight up. but it is appreciated. and the search button will be deffinitly used from now on thanks
Old Jun 29, 2009 | 05:45 PM
erichsherrill
my deployment will end shortly and ill keep you updated on my install and how it goes
Old Jun 29, 2009 | 06:46 PM
Sharif@Forged
Forged Performance
I think you will be just fine. Give it a good compression, and leakdown test to confirm. But if the engine is strong, and not consuming much oil, you should be fine. The VQ35 is engineered to run for 200K miles.
Old Jun 30, 2009 | 12:08 AM
nyqueenz's Avatar
nyqueenz
This is an example of an engine at 118k miles.. car was maintained throughout out the years I had position of it.
2003 G35 VQ35 DE.. going FI with proper internals.
good luck with your build...
Noted....
bad motor mount.
water pump going, going... "gone"
low press oil issues...
broke seals..
Cams look rough..
Bottom line.. make sure u know what you are gettin yourself into.. If i boosted on my stock block.. Car prob would last very long... hope this helps.
