No Throttle(help plzzzz)
Old Jul 28, 2009 | 11:41 AM
Jtran Studios's Avatar
Jtran Studios
Vendor - Former Vendor
go get the abs scanned, might be the wheel speed sensor going back throwing an erratic signal making the car go into limp mode and shutting down the throttle.
Old Jul 28, 2009 | 11:57 AM
GREWAl's Avatar
GREWAl
Originally Posted by psychoballistic
I had the same problem for a while going into limp mode with no throttle response.
I replaced the APP sensor and it did nothing, still had the problem. So I disconected my wiring harness and cleaned it all out and then blew all connecting point with my compressor and knock on wood have not had the problem since. Check or corrosion on the pins, but make sure to take the plastic off of the wiring harness otherwise you won't be able to get in there well to clean it.
Thats what happened to me and how I solved it, hopefully it's not your ecu.
was ur car in limp mode all the time or u cud drive it for sometime.
cuz i can drive it for 20 min after i reset the ECU.
Old Jul 29, 2009 | 08:34 AM
psychoballistic's Avatar
psychoballistic
I could drive it for like 15-30 minutes and then into limp mode, pull over and shut off turn back on. When it would go into limp mode it would continue to happen over and over again. Once and a while it would happen on startup when I would let it warm up, and I would have to shut it off and then restart it, drive it for a little while and then it would happen again.
Question, is the gromet on the passenger side behind the battery still sealed up or was it ever opened up to run anything in there?
Old Jul 29, 2009 | 09:32 PM
GREWAl's Avatar
GREWAl
are you taliking about the IPDM E/R, if yes then u r right cuz my ipdm is looks replced from its shape as i can see the whiteink used to mark nissan by used car parts ppl.
will try your trick today hope it gets fine after this
thanks for ur help bro will update you soon.
Old Jul 30, 2009 | 07:55 AM
John@z1's Avatar
John@z1
Z1 Motorsports
Sounds like a Cam sensor.
Old Jul 30, 2009 | 09:52 AM
psychoballistic
PM replied too.
Old Jul 11, 2011 | 06:56 AM
cperkins86's Avatar
cperkins86
i had the same problem a couple of years ago. took it to nissan and was told it was the TPS. they replaced it and called me back "not your TPS, its your ECU" so the ECU was then replaced and i didnt have a problem for over a year. it has recently started doing it again though
pslamp32
Feb 8, 2017 09:07 AM
Darkspy
Sep 7, 2015 09:09 PM
