My APS TT G35 build is almost complete...
Old Aug 12, 2009 | 07:44 AM
  #41
Cass007's Avatar
Cass007
It wasn't the idle that was the issue, it was coming off a WOT run and then taking my foot off the gas completely that was causing a stumble, so the idle was bumped to prevent any stalling issue. I thought the hot start issue was universal with Utec and larger injectors .
Either way, that POS is out of my car now for good.
Old Aug 12, 2009 | 08:23 AM
  #42
Blck350z's Avatar
Blck350z
Just have them wait till the "real" tuner gets back. I worked on my car for 1.5 months and Cass007... like he said ... he has been carless for almost a year!!! consider yourself lucky that they didn't blow the motor tinkering around and that it has only been 2 weeks. Just have them LEAVE the car sit there till the tuner gets back.
Also my Utec did have hotstart issues with RC550 injectors That goes w/out saying (get used to it if you're not changing anytime soon) and the idling issue... it should idle fine... i had my idle set to 750 rpm and my friend has his set to 1000....
Old Aug 12, 2009 | 12:35 PM
  #43
lope483's Avatar
lope483
Originally Posted by Chef-J
Do you need same thread in tuning section?
Didn't you said they using a utec and cobb AP?
there wasnt an AP, it was a diagnostic device...cant remember what he called it though
Old Aug 12, 2009 | 12:38 PM
  #44
lope483's Avatar
lope483
Originally Posted by Cass007
This advice is 100% correct. The 600cc injectors will need an idle bump and will most likey require some pedaling to get the car started when hot. I would find an experienced VQ shop to retune and tweak the Utec settings to get any more power.
My Utec always had off throttle and hot start issues and I hated it. Start saving for a real EMS.
the problem is there isnt a "real VQ tuning shop" within 300 miles of me. and the only one id want to look at my car is Forged.
and i talked to Ryan at forged this afternoon. he said they have done a ton of installs with the APS kit and pump+injectors w/ UTEC and they almost never run into this issue. when they do its usually a vacuum leak or the intake air control valve.
it cant be a vacuum leak though cause they did a smoke leak test.
Old Aug 12, 2009 | 12:41 PM
  #45
lope483's Avatar
lope483
Originally Posted by str8dum1
^YMMV, i did not need an idle bump, nor do i require pedaling to start. Sounds like its a bunch of guys randomly trying settings on the UTEC. The UTEC is so easy to get to idle correctly, make me wonder if theres a vacuum leak.
thats what ryan @ forged said but they did a smoke test.
Old Aug 12, 2009 | 12:44 PM
  #46
lope483's Avatar
lope483
Originally Posted by jining
I duno... I idle @ 650rpm just fine with utec and dw600, im going to bet my money those guys dont know what they are doing
Ask them if they have a smoke machine to test and see if theres any vac leaks?
they are used to tuning Termi mustangs so they arent super familiar with the UTEC. and they have only done one 350zTT install in the past so this is their first G35.
they are recommending a fuel return setup now. i said EVERYONE on the forums, as well as ryan when i talked ot him, said ou dont need one unless you are running serious hp, like 500+. they said they talked to Jermaine at turboXS and thats what HE told them to do.
Old Aug 12, 2009 | 12:46 PM
  #47
lope483's Avatar
lope483
they confirmed this morning that it was specifically a hot start issue. it fored right up and idled perfectly this morning when the engine was cold.
regardless, i have to wait for the shop owner/tuner to come back. he said he didnt want them ****ing with it anymore and he would finish tuning it when he got back. on freaking monday.
Old Aug 12, 2009 | 02:08 PM
  #48
Chef-J's Avatar
Chef-J
Booooosstt!!
https://my350z.com/forum/tuning/4504...re-please.html
So what, where you want us to post?
Old Aug 12, 2009 | 02:27 PM
  #49
Chef-J's Avatar
Chef-J
Booooosstt!!
i they were sitting in it messing with the UTEC and accessport-looking diagnosing computer.
At 400whp, you don't need RFS, but you are at "it's good to have". But you can walk away with it. RFS, atleast stage 0 will cost you pretty close to 600~700 dollars ( labor/part ) It's up to you.
Old Aug 12, 2009 | 05:04 PM
  #50
str8dum1's Avatar
str8dum1
you def dont need a RFS to solve the problem that you are having....
hot start does not affect the idle though. Once started it should run perfectly.
Just wait til monday and see how that goes.
Do you have a boost/vac gauge? You should be seeing -10psi or -20mmHg at idle. Anything higher means you have a leak.
Old Aug 12, 2009 | 06:03 PM
  #51
lope483's Avatar
lope483
yea thats pretty much my plan. and yes i have a boost guage and its dead on. they did a smoke test too and nothing.
Old Aug 13, 2009 | 07:41 AM
  #52
G3po's Avatar
G3po
Bumping the idle may be needed "if you ever upgrade to lumpy cams" and it masks some idling issues . But it does not help " off thottle" starting. Sometimes when you must tap the throttle to get the UTEC to get it's chit together in the first few seconds , you may also thow annoying mis-fire codes. With a minor reflash (ie via Osirus" you should not need to do this and idle and startup operation operation will be just like stock even with the DW 600ccs.
UTEC is not a paper-weight "per-se" but it has several annying behaviors.
The Haltech or UTec + Osirus provide far more seemless stock-like behavior.
TBH I was able to get a better idle with a unihip and 600s vs a UTEC. The main reason I ditched the UTEC is that it was extremely "notchy" at high RPM , when you drop in and out of boost. The CPU is not adequate to keep up with the rapid MAF ot MAP transitions. So it's kinda useless for road course use. Ask any reputable shop that has UTEC in Z/G experience for a similar scoop.
Old Aug 13, 2009 | 09:13 AM
  #53
lope483's Avatar
lope483
do i really need a UTEC PLUS Osiris? cant i just go with Osiris and ditch the UTEC?
Old Aug 13, 2009 | 09:44 AM
  #54
str8dum1's Avatar
str8dum1
he means a simple reflash to correct for the bigger injectors. The UTEC can only scale MAF voltage so much and the stock ECU wants to fight that. Reflashing the ECU with Osirus to correct for the new injectors will make the UTEC transition perfectly between on and off boost. Most people just live with the UTEC. I think its just fine.
Of course, you can get a full dyno tune using Osirus and drop the UTEC completely.
Old Aug 13, 2009 | 10:21 AM
  #55
lope483's Avatar
lope483
what would you recommend? it just kills me to have to buy an Osiris tune when ive already spent the money for UTEC. i know i can always sell it, but its just a hassle.
from the comments on the boards however, it seems Osiris is just a much better platform anyway.
Old Aug 13, 2009 | 01:46 PM
  #56
G3po's Avatar
G3po
Yes what I meant was a refolash. Osirus is just the "new" way to do it .It's easier to go back to stock and no need for shipping your ECU. Also note an Osirus reflash can get you a few things UTEC never can can: raised rev limiter, raised speed limiter, no hot or cold start issues etc.
Whether to ditch UTEC or not?. It depends on how you want to use the car , how **** you may be and ifyou have the funds. If UTEC and the PMAS had been available to me 2.5 years ago , I wouid have tried that route.
For me personally I was very disappointed with the UTECH and it's un-advertised features. PS . My tuner (ZCG) also hated the user interface. Note ZCG in SJ has done doezens of succesful APS installs. I note you live in Sactown. Be stealth, and avoid gettgin popped by the the po-po , I learned that the hard way.
Old Aug 22, 2009 | 05:35 AM
  #57
lope483's Avatar
lope483
so i got my car back yeasterday.
we ditched the UTEC and went with an Osiris reflash. the idle problem all but went away. it is a little lumpy still but no stalling and its a million times better. its getting better still with every mile i put on the car.
we dyno'd at 7.4psi and hit 397rwhp and 377rwtq. after we iron all the bugs out we're gonna bump it to 9psi for a high boost setting for "special occations"
i am absolutely thrilled with the car. im at work right now so i dont have pics or the dyno sheet but will get them when i can. this thing hauls ***.
the only thing i really dont like is the Z1 clutch. its a 6-puck and a single-mass flywheel and chatters like CRAZY. its also a ***** to start in 1st. but other than that its ok. ill be upgrading to a better streetable twin-disk setup in the future.
ill definitely be updating this thread later though. thanks again for all the support and advice.
Old Sep 5, 2009 | 10:06 AM
  #58
G3po's Avatar
G3po
Default Osiris
So are you now running the re-flash with the stock MAF or the PMAS?
Also if you bump the idle up 200rpm or so , the idle will be less bumpy and you clutch will be less annoying in stop-n-go. To get an idea of that imporvement jsut comare how it drives with the AC ov vs. off. AC on the ECU bumps the idle.
350Z_Al
Oct 29, 2020 07:44 PM
Tochigi_236
Sep 27, 2015 03:40 PM
