ATI blower cog bolt
Old Sep 19, 2009 | 02:20 PM
beyondfantasy's Avatar
beyondfantasy
Default ATI blower cog bolt
The bolt on my ATI blower cog, (the bolt's head faces to the rear of the car and the cog is the most driverside cog) backed itself out twice.
No loctite was used.
Now on the third time trying to get the bolt tightened on with loctite, i'm not able to get the bolt screwed in all the way as whatever is supposed to lock it down on the other side is spinning. I can't remove the bolt either as trying to unscrew it, the bolt just spins endlessly. I'm not sure if it's spinning or if the blower shaft broke?
Does anyone know about this? or if theres a way i can lock down the other side of the bolt so i can put it all the way in or remove it?
Old Sep 19, 2009 | 02:43 PM
Boostedtrack350's Avatar
Boostedtrack350
Where in Louisiana are you? i also have the ATI and could maybe take a look at it.
Old Sep 20, 2009 | 10:05 AM
beyondfantasy
actually la meant los angeles, thanks for the offer though!
any thoughts on why the bolt doesn't screw in completely and just spins?
Old Sep 20, 2009 | 06:38 PM
Boostedtrack350
Sorry I have no idea. give Forged Performance a call. I'm sure Sharif can point you in the right direction
Old Jun 24, 2011 | 01:56 AM
pimpin714style's Avatar
pimpin714style
Im having the same issue right now, was this ever resolved? cant get the back bolt off (just turns and turns) and pulley just spins freely(ati says its a shaft key) but i still cant get the bolt free to try and fix.
Old Jun 24, 2011 | 05:29 AM
beyondfantasy
Yeah, I couldn't find anyone that could help fix themselves, so i called ATI and started a repair order and shipped the entire blower to them. One of their techs replaced the shaft key and sent it back good as new.
AbrasiveRaysive
Sep 20, 2021 02:29 PM
