GTM Oil cooler install
Old Sep 21, 2009 | 04:48 AM
plumpzz's Avatar
plumpzz
Default GTM Oil cooler install
Does anyone have pictures of the oil cooler install? My fittings and lines are sitting lower than I'd like and I just want to see how others routed the lines and placed the fittings.
Thank you
Old Sep 21, 2009 | 05:13 AM
CeBrwn5454's Avatar
CeBrwn5454
I had the same problem with the lines sitting too low. GTM needs to include 90 degree fittings NOT 45.
Anyway, what I ended up doing was mounting it on the passanger side. I cut a slit in the front brace (aluminum piece) and slid the cooler up about 3 inches.
Just coil your lines, that are also WAY too long, there is no other way to do it.
Old Sep 21, 2009 | 06:46 AM
Sam@GTM's Avatar
Sam@GTM
GT Motorsports
Thank you
Here is a link with some pics
https://my350z.com/forum/shop-builds...p-563rwtq.html
Sam
Old Sep 21, 2009 | 07:04 AM
Sam@GTM's Avatar
Sam@GTM
GT Motorsports
It is really depends on where you are positioning the oil cooler 45 will work but if you are a little too low to start with then the 90 will defiantly help that .
We do Have the 45 and 90 available . I will add an option to choose from on our web site to make things easier.
Sam
Old Sep 21, 2009 | 07:40 AM
Speqz's Avatar
Speqz
is the oil cooler on the site?
Old Sep 21, 2009 | 07:59 AM
Sam@GTM's Avatar
Sam@GTM
GT Motorsports
http://gtmotorsports.com/product.php...cat=266&page=1
Sam
Old Sep 21, 2009 | 09:03 AM
CeBrwn5454's Avatar
CeBrwn5454
Wish I had known about the 90's a few months ago....oh well! GREAT product.
Old Sep 21, 2009 | 09:50 AM
plumpzz's Avatar
plumpzz
My car is real low. I'm going to need a line with the 90degree bend on one end.
Old Oct 7, 2009 | 06:07 AM
ExtaZ33's Avatar
ExtaZ33
Bump for more pictures of this kit installed. Just want to see a good full shot.
Old Oct 19, 2009 | 11:09 AM
ratm68's Avatar
ratm68
I don't have the GTM kit, but my cooler is bolted to the underside of the bumper brace/support on the driver side. I did that so the lines can ran naturally without bunching up. Basically, on a G, it sit right behind my driver vent on my nismo bumper to give reference. Clearly this wouldn't work if the brace is removed for intercooler installations.
Old Oct 19, 2009 | 11:34 AM
plumpzz's Avatar
plumpzz
Ill be installing a BBK soon. I will take pictures of the cooler and post them up.
Old Oct 19, 2009 | 07:55 PM
UMW350Z's Avatar
UMW350Z
please do, don't forget. I'd like to see these
Old Apr 25, 2010 | 11:31 AM
plumpzz's Avatar
plumpzz
I forgot to take pictures but her is an update.
I put 3k miles on it, and the 45 degree AN fitting is leaking. In order to make the lines run, I had to bend the line and the added pressure on the fitting caused the O ring to fail and it is leaking. GTM needs to include 90 degree bends NOT 45 degree bends. People ordering should specify as well!
I will be replacing the fitting with a new one soon and it should be fine otherwise.
Old Apr 25, 2010 | 11:40 AM
MDHRZ's Avatar
MDHRZ
Just ordered the kit last week. Need to check to see if it comes with the 90.
CeBrwn5454's Avatar
CeBrwn5454
Were your lines WAY too long as well!?
Old Apr 25, 2010 | 11:42 AM
plumpzz's Avatar
plumpzz
Yeah.. I sent Sam a PM with suggestions to improve the kit. I am replacing all the fittings with 90 degree bends. The added stress from the long lines is wearing out the O rings too fast. I have oil spilling on top of my oil cooler and leaking out from the thermostat.
Old Apr 25, 2010 | 11:43 AM
Sam@GTM's Avatar
Sam@GTM
GT Motorsports
Sent you a pm so we can help you out .
Sam
Old Apr 25, 2010 | 11:44 AM
MDHRZ's Avatar
MDHRZ
Are the 90 degree bends available on GTM's site?
Old Apr 25, 2010 | 11:45 AM
Sam@GTM's Avatar
Sam@GTM
GT Motorsports
We did change them to the 90
Sam
Old Apr 25, 2010 | 11:50 AM
MDHRZ's Avatar
MDHRZ
Sam
Thanks!
