Cosworth intake plenum + injectors
Old Sep 25, 2009 | 07:58 PM
CAB350z's Avatar
CAB350z
Default Cosworth intake plenum + injectors
Before people hate on me, I did a quick search and i found much talk about the plenum and fuel rails but i could not find much on how much room there is for injectors. Im putting in 440cc injectors when my turbo kit comes in and i was wondering if i will need the spacer or if the injectors will fit?
Old Sep 25, 2009 | 10:14 PM
ttg35fort's Avatar
ttg35fort
Professional
It depends on what brand of injectors you have and which fuel rails. Injectors that are the same size as stock injectors, such as the Deatschwerks injectors, should not need the spacer.
If have RC or HKS injectors, you will probably not need the spacer if you use Cosworth fuel rails, but will if you use any of the higher flow fuel rails (e.g., CJM, AAM, etc.).
Old Sep 26, 2009 | 06:42 AM
rxkevin's Avatar
rxkevin
I am using Sard 650cc injectors with CJM rails and I did not need the spacer.
Old Sep 26, 2009 | 06:44 AM
Jay'Z's Avatar
Jay'Z
Good info.....
Old Sep 26, 2009 | 07:39 AM
jonnylaw's Avatar
jonnylaw
DW 600's and GTM fuel rails fit just fine with the Cos on my setup.
Old Sep 26, 2009 | 07:47 AM
TheMinel's Avatar
TheMinel
that's good to know, I have exactly the same, and already the fuel rails needed spacers (about 10mm) to be screwed on properly! I will also go Cosworth Intake manifold, and was looking to get a spacer too, I guess I will see how it goes without it first!
Old Sep 26, 2009 | 10:16 AM
BriGuyMax's Avatar
BriGuyMax
Turbo Whore
I have DW 650s and CJM rails and I used 2 gaskets just to be safe, but I didn't have any issues.
