stock or lightened crank pulley for F.I. ??
Old Sep 26, 2009 | 05:34 PM
sullyz366's Avatar
sullyz366
Default stock or lightened crank pulley for F.I. ??
Is there any benefit to using an aftermarket lightened alum crank pulley or stick with the heavy steel stock crank pulley on a vq35de with rods and pistons with single turbo for 400-500 hp range??
Old Sep 26, 2009 | 05:47 PM
Nexx's Avatar
Nexx
neither, go with a harmonic damper pulley.
Old Sep 26, 2009 | 07:58 PM
Sylvan Lake V35's Avatar
Sylvan Lake V35
+1 ATI or Fluid Damper
Old Sep 26, 2009 | 08:02 PM
Jay'Z's Avatar
Jay'Z
I got fluidampr, so far so good...
Old Sep 27, 2009 | 01:40 AM
jpagano's Avatar
jpagano
I am using the UR lightened crank pulley, with the Greddy TT kit for 3 years. No problem here
Old Sep 27, 2009 | 03:27 AM
Cass007's Avatar
Cass007
The conventional wisdom is that lightweight pullies and F/I are a no go.
I ran a brand new Fluidampner pulley on my high HP builds (2 motors) and both ate main bearings within 1000 miles. I am now back on the stock pulley and will send the Fluidampner out to AAM to be rotational balance tested on a crank up to 8K rpm before re-installing on the car.
If the pulley is bad it should have caused a noticable vibration, but at this point I will error on the side of caution every time.
Old Sep 27, 2009 | 06:32 AM
Chris@FsP's Avatar
Chris@FsP
Vendor - Former Vendor
If my choice was between stock, and a lightened pulley, I would choose stock every time. Although, I have heard good things about the ATI pulley.
Old Sep 27, 2009 | 07:01 AM
westpak's Avatar
westpak
SFZCC
I had the UR pulley from NA that I left on when I did the TT but when I went to the built block I used the stock one, it is light enough that I didn't see the need for a light one
Old Sep 27, 2009 | 07:57 AM
XKR's Avatar
XKR
....I am a living example of what will happen if you use a lightweight pulley on an FI'ed car...I had to change my crank. Stay away from that stuff when you have an FI car.
Old Sep 27, 2009 | 08:38 AM
frankie945's Avatar
frankie945
^ 1 Stick with stock. Spend your money on something else that benefits FI.
Old Sep 27, 2009 | 08:54 AM
Zivman's Avatar
Zivman
times that by 2 ->
I have the bad crank sitting under my workbench to prove the damage they can do.
I am running an ATI superdamper on my current setup
Old Sep 27, 2009 | 09:14 AM
XKR's Avatar
XKR
Originally Posted by Zivman
times that by 2 ->
It was your warning I first saw....soon after...Sharif found the problem
Old Sep 27, 2009 | 11:56 AM
jonnylaw's Avatar
jonnylaw
ATI here.
Old Sep 28, 2009 | 06:18 AM
psychoballistic's Avatar
psychoballistic
Wow, had similiar interest in installing Light weight pulley's, glad I held out on doing so. Thanks for the insight guys.
Fixxxercask
Nov 9, 2015 11:10 AM
