What could be wrong?
Old Oct 13, 2009 | 05:42 AM
ktown z's Avatar
ktown z
Default What could be wrong?
Well I started my car this morning and it was running like crap. The idle was very bad and sounded like a very bad misfire. It reminded me when I had cams installed on a different vehicle and the timing was off when it was initially started. When I turned the key to the off position the car ran for a little over 1 sec then died. I started it 3 times and all three times it did the same thing. I am running a HKS f-con and it has been over 100% humidity for about 1 week were I live. So what could be wrong with my gem?
Thanks,
James
Old Oct 13, 2009 | 05:58 AM
SmallTuner's Avatar
SmallTuner
its realy hard to tell.
did u get any engine codes ?
did u check ur maf sensor connector if its in place ??!?!?!
Old Oct 13, 2009 | 06:07 AM
djamps's Avatar
djamps
Has it rained? You could have water leaking through the firewall onto your EMS. Discovered this happening on my car the other day (which was my fault from a recent alarm install)...worst place in the world for the loom to go through IMO...
Old Oct 13, 2009 | 07:03 AM
ktown z's Avatar
ktown z
It has been raining for 2.5 weeks nonstop here, but the ecu is clean and dry. The car ran great 2 days prior to todays start up. I do not have my MAF installed because I run a MAP with the F-con and I always have a check engine light on.
Obadabot
Jun 18, 2023 11:31 PM
derekinthez
South East
Sep 28, 2015 06:35 PM
