Greddy 20g turbo seal
Old Oct 29, 2009 | 02:59 PM
Juice+'s Avatar
Juice+
Default Greddy 20g turbo seal
Well my car has been smoking out both exhausts. I did some test and found its not the headgasket. since my car has been sitting I noticed that oil was leaking from what looked like the oil cooler on the drivers side. Once I jacked it up to check everything out, I noticed that the oil was leaking from the turbo and making a route through the undertray were it dripped out by the oil cooler. I then took the charge pipe off and there was ALOT of oil in there. So oil is blowing through the turbo, into the intercooler, and then into the motor...ugh So to me it sounds like I need to get the seal replaced. Where do I get this fixed at? About how much is it going to cost?
Old Oct 29, 2009 | 04:13 PM
deanfootlong's Avatar
deanfootlong
well, a typical turbo rebuild will cost you around 400 bucks. i believe forced performance does it.
Old Oct 30, 2009 | 04:20 AM
Juice+'s Avatar
Juice+
Thanks I figured it would be around 400.
Old Oct 30, 2009 | 06:28 AM
str8dum1's Avatar
str8dum1
blouch and forced performance are 2 of the bigger ones. ATP might do it as well. I've read that FP has a pretty long turn around. Cass0007 had to have his turbos rebuilt twice, so you may wanna browse his thread.
and thats at least 400 per turbo. hopefully both yours arent messed up
sales@czp
Sep 23, 2019 03:30 PM
350z82
Oct 1, 2015 06:25 PM
