Need help virtually diagnosing ...
A friend called me to have me help him try and figure out what is going on with his car, he has APS TT running around 10psi (~400whp), he has had no issues until recently he drove into a rather large puddle and then his car started acting up. Also, to cloud the issue he was also rear-ended shortly after the issue started but he assures me that the issue started before the collision.
The car is driving 100% fine under vaccuum (starts and idles fine and has solid fuel pressure of 40lbs on 650cc injectors) but as soon as boost starts to come in the car bogs and dies, after connecting the laptop you can clearly see that as soon as 1psi of boost is hit (3000ish rpm) his injector pulse rises to 22ms and his duty cycle is hitting 64% ... there is a very strong smell of gas if he doesn't lift.
Anyone have a clue?
Could this just be a simple boost leak ???
Anyone have a clue?
What is the utec crossover? If it is 1psi then it cant be the MAF because Utec should be in Open Loop. If it is the MAF then your problem should be in vacuum. Are you using the manifold as a boost reference for the utec map sensor? If so then it may not be a boost leak because you are reading from the manifold already. Make sure you are in the right switch/map in utec. Hitting that puddle might have cause the Utec to switch to a different map. Please post some logs since you have a utec. what load/cell in the map are you hitting at 1psi?
the car sputtered once right before the accident, but at the same time I had low oil and the vehicle tripped a cam sensor light because of it. Therefore, I'm not positive if it was due to the hit or due to the puddle that I am having the issues that I am now. It goes into the shop tomorrow, but I was hoping to have some answers for them. Learned my lesson about the oil, and changed it the next day...but this issue still remains
As for the problem, I believe that it is a UTEC problem. Impact could damage an EPROM inside the CPU. Casing can short circuit some of the contacts inside the CPU. I had a similar case my self. Just take out UTEC, lie it on the floor of the car with the ground in place, and see what happens.
If you are throwing cam sensor codes that is most likely your issue. I've seen it sometimes when these sensors go everything seems fine until boost. I highly doubt the UTEC spontaneously changed maps.
cam light hasn't came back since oil change...was just low on oil for that to trip. It goes to a local shop today to see if they can figure it out. The other drivers insurance will be picking up the tab for it too as long as they can prove (or at least argue the point well) that it was accident related.
I'm assuming that the MAP sensor is reading OK, is this correct? Make sure it is and that the Utech is getting the signal. Also, make sure all of the connectors are dry. Water will conduct electricity (unless is distilled water), and could be throwing off some of the sensor readings the Utech is relying on.
It was some hose hidden on the back of my engine that had come undone. I reattached it and it was fine.
My gut feeling is that something got wet somewhere ...
