what size pistons to get??
Old Nov 5, 2009 | 06:31 PM
ccchaorule's Avatar
ccchaorule
Default what size pistons to get??
i am going with wiseco pistons.. but was wondering what bore to get?? 95.5 stock bore?? or 96mm with a .020 over?? what are the advantages of the .020 bore?? this is for a shortblock... thanks
Old Nov 5, 2009 | 06:37 PM
Sylvan Lake V35's Avatar
Sylvan Lake V35
96mm is 0.020 over stock bore, 0.020" = 0.5mm. I wouldn't recommend stock bore block and pistons you should use the 96mm pistons and have the cylinders bored 0.020 over and honed so the rings can seat properly.
Old Nov 6, 2009 | 08:54 AM
ttg35fort's Avatar
ttg35fort
Professional
0.020" over is typically used the first time a block is re-built.
streetzlegend's Avatar
streetzlegend
Yea you should go with 96mm, benefit is basically, bore the cylinders and get rid of imperfection as well as make sure its 100% round, you usually cant just put in stock size pistons without resurfacing the cylinders. basically what was mentioned in previous post
Old Nov 6, 2009 | 09:27 AM
djtimodj's Avatar
djtimodj
You also gain 60 ish cc of displacement!! WOOHOO!
Old Nov 6, 2009 | 10:10 AM
Sharif@Forged's Avatar
Sharif@Forged
Forged Performance
There is no way to insure precise and correct piston to wall clearances, without a .020 over piston, and the associated machining. Although standard bore pistons can work, it's not a chance I would take or you may end up with some cylinders slightly tight, and others too loose.
