AAM stage 2 fuel system question?????
Old Dec 9, 2009 | 09:39 AM
djtimodj's Avatar
djtimodj
Default AAM stage 2 fuel system question?????
The AAM stage 2 system uses a bosch 044 big fuel pump pulling off a swirl pot that is fed from the walbro 255 intank pump. My question is as you increase base fuel pressure say from 3 to 4 bar you lose volume due to the increased fuel pressure.
If you could use the bigger (higher flowing) Bosch 044 could you run smaller injectors at a higher base fuel pressure and make the same power as larger injectors at a lower pressure?
Any one have a view on this?
Ps. This would be going into a 500 ish whp build.
Old Dec 9, 2009 | 09:49 AM
str8dum1's Avatar
str8dum1
that would work to a point where you max out the physical limitations of orifice flow.
cant you save a couple hundred bucks for some 600cc injectors and do it properly? Its absolutely crazy to cut corners on the fueling.
Old Dec 9, 2009 | 06:50 PM
zman1982's Avatar
zman1982
pslamp32
Feb 8, 2017 09:07 AM
NissanZcrazy
Nov 2, 2015 06:03 PM
SpartanZ32
Oct 22, 2015 09:36 AM
TrackFiddy
Sep 24, 2015 11:40 PM
