Vortech SC on a 100k miles engine?
Old Dec 11, 2009 | 07:45 AM
scenehouser's Avatar
scenehouser
Default Vortech SC on a 100k miles engine?
Hey guys,
Is it madness to put a Vortech Supercharger on a stock block and driveline that has done a 100k miles?
I'm asking because I've found a cheap 350Z with 100k miles in excellent condition..
I've also checked out two 40k miles cars which were both in much much worse condition and a lot lot more expensive...
Old Dec 11, 2009 | 07:54 AM
TJGILROY's Avatar
TJGILROY
whatever floats the boat...but it seems like a F/I would put more strain on your engine parts...and if they've already been through 100k, you might be chancin' it
Old Dec 11, 2009 | 07:57 AM
Chris@FsP's Avatar
Chris@FsP
Vendor - Former Vendor
As mentioned hundreds of times on this forum, have the motor checked out (compression, leakdown tests) to make sure the engine is still healthy. Any problems that may exist in the motor now will only be amplified by adding boost.
Old Dec 11, 2009 | 08:05 AM
jbaker1121's Avatar
jbaker1121
No, give me the vortech SC instead for my FX.
Old Dec 11, 2009 | 10:42 AM
rx7/350z's Avatar
rx7/350z
i have 107 on mine . vortech 40k miles. runs great
Old Dec 11, 2009 | 11:01 AM
Juztin's Avatar
Juztin
as long as your comp. test and leak down check out its fine. I've been there with no problems, even with 10+psi (480+whp) and running the hell out of the engine. Just get a solid tune and if your nervous just turn down the boost for less power.
Jambo016
Sep 16, 2016 01:08 PM
Fixxxercask
Nov 9, 2015 11:10 AM
