need recommendation for front tires to go with R888 in back
Old Mar 8, 2010 | 09:26 AM
str8dum1's Avatar
str8dum1
nitto also makes the NT05 in 275/30/19 which have good reviews across platforms.
Old Mar 8, 2010 | 09:40 AM
350z 6spd's Avatar
350z 6spd
Originally Posted by rcdash
What is odd about the RE050A pole position tires is that the treadwear varies drastically among sizes, ranging from 140 to 280! The 275/30R19 should be stickier than the RE-11.
My re050a's are 140 and the re-11s definitely stick better than the re050a's did. That could also be due to the fact that my most recent memory of the re050a's is when they were pretty worn out.
Old Mar 8, 2010 | 09:55 AM
GreenGoblin's Avatar
GreenGoblin
I was going to suggest the Nitto nt05.
Old Mar 8, 2010 | 09:56 AM
Nealoc187's Avatar
Nealoc187
The RE11 and AD08 are quite a bit better tires in all performance categories than the other tires you have listed (except maybe serious standing water hydroplane resistance, the PS2 and F1 GS-D3 are really good in the wet). RE11 and AD08 far outstrip the RE050A P, PS2, GS-D3, etc in all facets of performance (not including road manners properties here like noise, harshness, tread life expectancy, simply talking about traction in all it's facets). How they're going to react to your camber/toe setup I do not know, whether their road manners are going to be to your liking I don't know, but if you put all 5 tires you listed on an identical car and run laps, the RE11 and AD08 are going to be the tires with the fastest lap times.
The Nitto NT05 is seems to have promise too from the very few reviews out there, but it's so new that it hasn't had the performance testing that the RE11 and AD08 have had yet (testing by autoX and road course guys, who are the guys I personally trust to tell the true nature and performance of a tire). No autoX or serious road course lappers use the PS2, F1 GS-D3, RE050A PP, etc. They're not at the top of the heap when it comes to traction like the RE11 and AD08s are.
Old Mar 8, 2010 | 10:07 AM
Nealoc187's Avatar
Nealoc187
rcdash, RA1 is not offered in 19" sizes and the T1R (he meant T1R, there is no such tire as the TR1) is pretty underwhelming when it comes to all out performance, not in the same league as the tires you've already said you're considering. not even worth mentioning in the same sentence.
Old Mar 8, 2010 | 10:54 AM
rcdash's Avatar
rcdash
Excellent posts - thanks. The RE11s are looking to be at the top of my list. I just looked at the T1R and RA1 and agree they don't fall into the same category.
The NT05 has a 200 treadwear rating but has gotten some pretty good reviews by track enthusiasts, including a FI G running 500+ whp on the track: http://g35driver.com/forums/wheels-t...05-review.html
They are available for $246 in 275/30R19 as str8dum1 indicated above with a 25.5" diameter and (only) a W speed rating. I'll eventually be looking for a rear pair and finding 295 or 305 may be an issue but that's a problem for another day.
Hmmm... tough call between the RE11 and NT05.
Old Mar 8, 2010 | 10:58 AM
scotts300's Avatar
scotts300
These v2 arms can go max positive of -1.8 camber (unlike the v1 which had way more adjustability).
I think this is only tire that could possibly out drive the R888 and still be used as a street tire. At $500 per tire, it's not cheap and it will wear out even quicker.
That's why I still have the V1s --> 3.2 degrees neg camber in the front. Pilot Cup Sports are overpriced for the performance they give, IMHO.
Originally Posted by thom000001
I'm thinking the same thing.
I have Khumo ECSTA MX's up front (245-40-18) on a 8.5 in wheel. I am considering a stickier front tire to help stop the "push"
last season I have scott's old BFG DR's (295-35-18), lots of grip (even lateral if you let them lean before laying down power).....
Haven't decided on new rear tires for this season yet.
Tom
Glad to see you're still rocking and enjoying these!
Old Mar 8, 2010 | 11:11 AM
rcdash's Avatar
rcdash
^ With the redesigned v2 SPL a arms you can go to +1 to -2.5 relative to stock (so about -0.5 to -4 camber on a stock car, but on my lowered car the range is -1.8 to close to -5 camber). I have the arms set to most positive camber possible (all shims in place).
EDIT: posting pics of the front tire camber wear - perhaps with the recent alignment, the current trouble spot won't be an issue? It looks like the area that wore down is now not even part of the contact patch.
Old Mar 9, 2010 | 10:27 AM
ZRuggernDC's Avatar
ZRuggernDC
I am pushing the Nitto NT05 for fronts. The best tire I have ever run on the street: BY FAR!
Totally satisfied. Was looking at the R888's before I tried out the NT05's. For me, there isn't another tire to look at switching to.
Old Mar 9, 2010 | 10:30 AM
blasian's Avatar
blasian
+1 for NT05s.
Old Mar 9, 2010 | 10:34 AM
Nealoc187's Avatar
Nealoc187
Ouch, that's a hard pill to swallow at $300 a piece of whatever R888s are in that size and barely any wear on the rest of the tire it seems. Sorry to see than man. BTW that looks like a toe issue.
Old Mar 9, 2010 | 10:38 AM
blasian's Avatar
blasian
Yeah, a few alignment shops told me that toe will eat tires faster than camber will.
Old Mar 9, 2010 | 10:59 AM
Glex25's Avatar
Glex25
^Bingo
Old Mar 9, 2010 | 11:03 AM
rcdash's Avatar
rcdash
Toe has always been in spec, supposedly... Obviously something was not right since the contact patch has changed after the recent alignment (current toe is IN 0.08 on both sides). I now have a firestone lifetime alignment and will be getting it checked out every 6 mos along with better monitoring for this kind of wear and tear.
To conclude this thread, after talking with Sharif, I've decided to go with the RE-11 up front. In addition I will replace the R888 in back with 305 RE11s after ZdayZ in preparation for time attack events over the summer. This will put me into a more competitive class and provide better year round street performance (the R888s are terrible in the 40-60 degF range). I understand that I will be losing some traction in the rear with this change but with the tires seeing mostly "street temps", it may not be so drastic (hopefully).
Thanks for everyone's input. The NT05 and AD08 are also great alternatives.
Old Mar 9, 2010 | 11:45 AM
Zazz93's Avatar
Zazz93
Yeah, look like a toe or suspension problem. If you look at the wear at the static position it looks like the steering angle is causing the wear and that would suggest caster or another steering geometry problem. An agressively cambered car should still wear fairly even along cambered profile of the setup. What's done is done, just be careful with the next set and get a good alignment shop to look it over.
Total toe-in should be in between 0-2mm
Good luck!
Old Mar 9, 2010 | 12:32 PM
rcdash's Avatar
rcdash
I wish I would've caught it earlier so I could have swapped driver and passenger side tires. Anyway, live and learn. Geometry is all correct now.
Old Mar 9, 2010 | 01:09 PM
str8dum1's Avatar
str8dum1
ha thats what my old front looks liked as well bc i didnt get an alignment after i dropped it. doh!
Old Mar 9, 2010 | 01:39 PM
  #38
rcdash's Avatar
rcdash
Well you are still one up on me since I got an alignment and still did that!
Old Mar 12, 2010 | 06:56 AM
  #39
Dubai's Avatar
Dubai
This might be a lil offtopic but I just put my R888 tires and was wondering is there any break in period before I start beating on them?
Old Mar 12, 2010 | 07:15 AM
  #40
rcdash's Avatar
rcdash
They love hot temps (and apparently low pressures, around 35 psi I hear) - go for it.
