few vortech revup questions
i just purchased a vortech v2 kit for my revup g35 and i have a few unanswered questions before install.
the kit im getting comes with 380cc injectors, if i install a walbro 255l pump, can i bypass using the fmu that comes with the kit and just tune with the unichip?
what kind of widebands are people using for tuning?
i searched and it seems noone makes a pillar pod for a sedan, i would just have to make a custom one, correct?
when tuning with unichip, did you make a new map, or take the 91 octane map and tweak that?
any inputs are greatly appreciated
I have all of the awnsers you need when it comes to vortech. I only had to look on the first page of the forced induction section. follow this link.
https://my350z.com/forum/forced-indu...questions.html
answers in bold
yes
AEM, Zeotronix, Innovative, etc
the pods just mount over the stock A-pillar. YOu could prolly make one from the coupe fit just fine with a lil heat and some trimming
you make a new map
yes
you make a new map
rich: you think the 380cc injectors without the FMU boosting pressure will be enough for his system? test pipes, full exhaust and 3.12 pulley is what he said he is running. I would think that the 380's would be maxed even with the FMU boosting the pressures up.
aem wideband is useless for tuning unless you have a utec piggyback. It doesn't come with software to log your wideband data. You have to be able to log if you're going to use the wideband to tune. Using it for just a gauge to view then it's a great gauge.
i use innovate. innovate and zeotronix both have logging capability.
I guess the innovative also logs rpm and boost as well?
YOu can capture AEM data using the serial port and quick drop into excel will convert voltage to actual AFR. but none of that is useful like you said unless it correlates to rpm, boost etc.
i'd never run 380cc injectors, but I was just answering his questions. 600cc is what I'd use as that will give all the head room needed for a stock block.
so 380cc is a no go? im just running the full kit, using the oem tune from the unichip. whenever i do get it tuned, i would definately step up my injectors, but i dont want to push it out of the box.
add the LMA-3 and that has the boost and rpm then the software logs it all together. AEM doesn't have anything to put boost, rpm, and wideband together unless you use a utec and use the logging on the utec.
yep, what he said which means keeping the FMU. The FMU is important to bump up fuel pressure when under boost in order to supply enough fuel. So either use the WHOLE stock kit or you'll have to upgrade your injectors.
FMU's were used in the 1980-90s and they are old technology so boosting fuel pressure is a crude way to go about getting the fuel that you need. I'm sure it would be fine but that's just my opinion. I'm sot sure about how a unichip and how large of injectors it can scale so if that's a limiting factor then I guess you gotta do what you need to do to make it work. The best way to go about it would be 600s and a utec along with a good tune which it sounds like you will be going to down the road.
You can use Cipher (from uprev) to log factory wideband.
350Z_Al
Oct 29, 2020 07:44 PM
