ems helppppp pleaseee
With the capabilities of the UpRev and Cobb re-flashing in the lower price range, and the Haltech, F-CON and ProEFI in the mid-price range, is there even a reason for anyone to use a U-tech anymore? I've never played with the U-tech, so I don't know all of its functionality.
as much as I want to give a funny answer,
the real answer is 2 fold
1) depends on how much boost you are running.
-The resolution is only 16x16. So if you run 15psi of boost you can tune at evrey 1 psi interval.
-The more boost you run, the larger the areas that have to be tuned in 1 cell.
So, I ran 15psi no problem. Once you get over 20 psi, you'd prolly want to swap EMS's
2) Injector size
-since the UTEC relies on the stock EMS for starting, it doesnt deal well injectors above ~600cc. The stock ECU just cannot scale them back enough, so you get potential hot/cold starts
-you'll often run outta injectors size before you run outta tuning resolution.
UTEC is still a viable tuning option. People that blindly say to go Haltech, Uprev, etc prolly have never used any of those (like Andrei above who is NA
!). They all have their problems/limitations as well as advantages.
2) Injector size
1. Third party WB support for self/street Tuner, unless you trust the OEM 02 sensor then go ahead and tune that with Osiris.
2. Active knock control on all rpm and it will only pull timing on the area you are knocking. With Osirs, it automatically switches to a high_Det map which will hurt overall power.
3. Overboost fuel base cutoff. For me this is a great feature especially for Turbo guys.
Those 3 things important to me and most street tuner so that alone justified for me sticking with Utec.
If you want protection the Utec will give you that.. Osiris won’t! If you want perfect drivability then yes Osirs rule over Utec on that side. For me protection > drivability because I'm on stock block.
2) Injector size
2) Injector size
I clearly asked a question, you know, with a question mark.
Also, I clearly indicated that I don't know all of the UTECH's functionality, which is why I asked the question.
Anyway, thank you for the clarification on the UTECH's functionality, which does indeed answer my question.
/\ that is why I gave a few answers..lol I'm just tired of all the Osiris/Cobb nuthugger that think Osiris is the next best thing since slice bread. Your question didn’t sound like you were looking for an answer but rather instigate how the Utec really has no place in this market.. Just my .02 but I guess I was wrong.
2) Injector size
2) Injector size
