Crankshaft questions
Old Jun 24, 2010 | 08:25 AM
scenehouser's Avatar
scenehouser
Default Crankshaft questions
Hey guys,
I received my crankshaft that I bought secondhand to replace my damaged crankshaft.
First thing I noticed was that the numbers are different. My own damaged one has 70-2 on it and this replacement has 25-1 on it. They look identical so this is nothing to worry about right?
Now I want to send it off for polishing. Should I ask for specific measurements? I want to use ACL racebearings..
Thnx
Old Jun 24, 2010 | 08:40 AM
Cass007's Avatar
Cass007
My understanding i s that after the crank is polished it will be measured along with the block and the correct size bearings would be ordered to ensure proper fitment.
I cannot help with your question on the crank markings.
Old Jun 24, 2010 | 03:54 PM
MREDDLE's Avatar
MREDDLE
alot of times those number are a date of casting, a code for the date of casting, or were it was casted. I wouldn't worry about it if the main and rod journals measure out the same.
Old Jun 24, 2010 | 06:37 PM
Glex25's Avatar
Glex25
Old Jun 24, 2010 | 08:20 PM
streetzlegend's Avatar
streetzlegend
Buy yourself a Micrometer set that measures down to .0001 and measure all the journals. That will eliminate all the guess work on which crank and bearings you need.
I too bought a used crank, I had it micro-polished and then measured the journals. They were exactly the same size as the fsm even down to the .0001.
Old Jun 25, 2010 | 02:41 AM
scenehouser
thnx guys
issyz
Jul 2, 2017 03:04 PM
Alexreyes
Sep 30, 2015 11:30 PM
