When is a twin pump needed?
Old Aug 11, 2010 | 06:52 AM
  #141
IIQuickSilverII's Avatar
IIQuickSilverII
Originally Posted by str8dum1
There's no High Z 1600cc. Make those and you would def make a killing across every import platform. And um dont make them like this LOL http://injectordynamics.blogspot.com...ctor-in-3.html
i think you are assuming your expectations based on the experience of the 1600cc
i dont think the ones on the blog is the same as they sell them, those are bastardized 450cc, but either way the chart and cars being tuned with it speak for themselves... look how under 2 milisecs the 1600c curve fluctuates ie idle partial throttle.
From their site: "We only sell matched sets, and within each set the dynamic flow rate (slope) will vary no more than +/- 1%, and the dead time (offset) will vary no more than +/- 20 microseconds which is equivalent to +/- 1% at a pulsewidth of 2 milliseconds."
Nominal Dynamic Flow Rate - 2000cc/min @ 3.00 Bar (43.5 psi) Using Gasoline at 52 Degrees C (125 Degrees F)
Maximum Differential Fuel Pressure - 9.0 Bar (130.5 psi)
Fuel Compatibility - Compatible with Methanol/Ethanol/All Known Hydrocarbon Fuels. Incompatible with MTBE/Nitro Methane/Nitro Propane.
Electrical Connector - Denso
Old Aug 11, 2010 | 09:51 AM
  #142
binder's Avatar
binder
:Fuel Compatibility - Compatible with Methanol/Ethanol/All Known Hydrocarbon Fuels. Incompatible with MTBE/Nitro Methane/Nitro Propane.
don't quite a few of the vp "ms" fuels contain mtbe? And i thought the "q" series also contained MTBE.
I know the MS fuels have MTBE because there is a warning on teh side of one of my cans. I don't have any Q to be 100% certain on though.
Old Aug 11, 2010 | 11:38 AM
  #143
str8dum1's Avatar
str8dum1
you can use any fuel, just Q16 causes the rings to swell reducing flow. It wont cause the injector to fail, but thats why they dont recommend it.
Otherwise you can use the Seimens NGI 2200cc with any fuel with no issue.
Old Aug 12, 2010 | 10:22 AM
  #144
binder's Avatar
binder
icic, i was just curious because i know quite a few big builds are using the VP fuels and i didn't know if they thought about the fact that the ID's say don't use the MTBE or not.
