How long does it take to install Zex TC window switch
Old Jul 10, 2010 | 01:41 PM
D_K's Avatar
D_K
Default How long does it take to install Zex TC window switch
Anyone know about how long it would take a professional to install this? I'm looking at getting it and paying a speed shop to install it.
Old Jul 10, 2010 | 04:03 PM
Cux350z's Avatar
Cux350z
hatersgonnahate
its going to take some time. Electrical stuff is a PITA when you have to route stuff through the dash and cut holes/terminate/check wiring diagrams ect.
Old Jul 11, 2010 | 10:35 AM
str8dum1's Avatar
str8dum1
probably an 30mins or less. just pull down the stock ecu and tap the wires.
If you are talking about install of an entire nitrous setup, ya that will take some time.
Old Jul 11, 2010 | 10:47 AM
Cux350z's Avatar
Cux350z
hatersgonnahate
itll take more than 30 min for them to get to the ECU...damn cupholder release tab is a PITA if youve never done it before.
Old Jul 11, 2010 | 12:20 PM
Ruthless18x's Avatar
Ruthless18x
At least an hour if they haven't done it before. The Zex instructions blow.
Old Jul 11, 2010 | 02:04 PM
str8dum1's Avatar
str8dum1
lol, i guess I was thinking of a G35. 4 or 5 mns for the ECU, maybe 10 mins to find the wires, and 15 mins to solder....
Old Jul 13, 2010 | 02:17 PM
D_K's Avatar
D_K
So like an hour tops ? I was looking over Zex's instructions and it seems like you can mount the unit inside the car or in the engine bay. I would like to have it installed inside the car but velcrowed to the carpet area near my right leg so no holes need to be drilled for mounting, so about an hour tops for a pro?
Old Jul 13, 2010 | 03:06 PM
Cux350z's Avatar
Cux350z
hatersgonnahate
I would say 3 hrs to be on the safe side. You dont want to rush this.
The final location of the unit will really dictate the amount of time itll take. It sounds like you want to run wires from the drivers side to the passenger side.
Old Jul 13, 2010 | 03:23 PM
03threefiftyz's Avatar
03threefiftyz
D_K fail continues........there is a nitrous forum.............and this isn't it .
