cheap gauge alternative (water/intake temp)
Old Sep 1, 2010 | 07:57 AM
  #61
djtimodj's Avatar
djtimodj
What does the force protocol do ? I don't want to do something to the ecu that may damage it.
Old Sep 1, 2010 | 09:55 AM
  #62
djamps's Avatar
djamps
It means the gauge will use only 1 protocol (the correct one) to talk to the ECU instead of trying them all every time you plug it in. NOT forcing the correct protocol is going to do more damage than not...
Old Sep 1, 2010 | 09:59 AM
  #63
Vas_Z33's Avatar
Vas_Z33
correct ^
Old Sep 2, 2010 | 09:13 PM
  #64
KingBaby's Avatar
KingBaby
Hardest Setting
here is where I mounted it...
Old Sep 8, 2010 | 06:14 PM
  #65
djtimodj's Avatar
djtimodj
Guys i got my gauge today. I want to do the forve protocol but which one do you force/??
Help? ! lol..
Old Sep 8, 2010 | 09:20 PM
  #66
accordfreak's Avatar
accordfreak
Old Sep 28, 2010 | 11:38 AM
  #67
JGTC_350z's Avatar
JGTC_350z
hi guys , quick question . how did you tilt the base so much? the stand i got with the gauge cant be tilted at the base as per the picture below
Old Sep 28, 2010 | 05:10 PM
  #68
accordfreak
bend the arm any way you want it.
Old Sep 28, 2010 | 05:19 PM
  #69
JGTC_350z's Avatar
JGTC_350z
it's it a solid plastic? i'll try it later when i get to my car . thanks
Old Sep 28, 2010 | 05:21 PM
  #70
accordfreak
it's some type of really hard rubber but flexible
Old Sep 29, 2010 | 06:14 AM
  #71
JGTC_350z's Avatar
JGTC_350z
thanks guys , got it twisted
Old Nov 11, 2010 | 08:11 AM
  #72
Z PHAT Z's Avatar
Z PHAT Z
I read the manual and can't find how to load/find the gauge for oxygen sensor reading. Any of you guys know how please help. Thanks.
Old Dec 12, 2010 | 11:57 PM
  #73
BlueDragonZ's Avatar
BlueDragonZ
mine just arrived...nifty little thing.
Old Dec 13, 2010 | 12:13 AM
  #74
350Zdj's Avatar
350Zdj
this thing didn't work on my Z.
it can read only the temperature but it wasn't even accurate. Maybe my ECU is messed up?
Anyways, i kept it plugged for a few hours. On my way back home all of my gauges (on the Z) just died, but the car was still running and I couldn't tell what speed i was doing lol. All alarms (ie. vdc, abs, srs, cel etc etc) lit up like a Christmas tree!
I pulled the plug, switch off the engine and everything were back to normal!
anyone experienced this???
Old Dec 13, 2010 | 12:17 AM
  #75
BlueDragonZ
Did you do the force protocol 9141 as discussed?
Old Dec 13, 2010 | 08:42 AM
  #76
350Zdj's Avatar
350Zdj
^will try that and see if i'm lucky.
thanks bro!
Old Dec 15, 2010 | 01:06 AM
  #77
BlueDragonZ
Did the Force Protocol 9141 before anything else and everything seems to be working fine. Already pulled a code and the SEL wasn't even on. But I knew there was something wrong since my idles have been very rough...it pulled a P0300 code, random misfire. That certainly explains my rough idle.
Old Dec 15, 2010 | 01:17 AM
  #78
Spork's Avatar
Spork
Hmm, hard to decide. I like gauges.
Old Dec 15, 2010 | 05:27 AM
  #79
mazymus's Avatar
mazymus
So is this thing worth it? Can I get this to replace AFR or oil temp? Ir is it more of a supplement?
Old Dec 15, 2010 | 05:30 AM
  #80
mazymus's Avatar
mazymus
Also does it fit in the cubby? Thanx
