cheap gauge alternative (water/intake temp)
Old Aug 21, 2010 | 01:42 AM
accordfreak's Avatar
accordfreak
Default cheap gauge alternative (water/intake temp)
Not sure if anybody's seen this but it seems to work pretty well and it clears engine codes too.. it plugs into the obdII port and get all the data from the ECU. real time.
http://www.ultra-gauge.com/ultragauge/index.htm
can't beat 40 bucks
I set mine for engine temp and intake temp read out
Old Aug 21, 2010 | 02:16 AM
0jiggy0's Avatar
0jiggy0
Wow, that's an amazing price.
Old Aug 21, 2010 | 02:55 AM
LaoSiFu's Avatar
LaoSiFu
Now you really got me thinking. Got a video clip of it?
~Robert
Old Aug 21, 2010 | 03:23 AM
jdm-v35's Avatar
jdm-v35
this seems similar to greddy informeter but for cheaper.
Old Aug 21, 2010 | 04:35 AM
Vas_Z33's Avatar
Vas_Z33
damnm.. for 40$. what do you got to loose?
Old Aug 21, 2010 | 04:39 AM
0jiggy0's Avatar
0jiggy0
No one wants a loose gauge.
Old Aug 21, 2010 | 04:48 AM
Vas_Z33's Avatar
Vas_Z33
loll lose* my bad, stupid iphones.. I just placed an order
Old Aug 21, 2010 | 08:04 AM
This is quite a diagnostic tool for $40.
Old Aug 21, 2010 | 08:10 AM
DavesZ#3's Avatar
DavesZ#3
You have to keep in mind that not all of those 74 possible gauges are available from the Z's ECU. But you can't beat it for a real-time monitor and code reader.
I already have an OBDII recording device (Davis CarChip) but ordered one of these to use with all my cars.
Old Aug 21, 2010 | 08:20 AM
cdoxp800's Avatar
cdoxp800
Cool. It would be nice to know what all it reads in our ECM's. They don't have the z listed on there Gauge Availability Estimator, but it looks like it works. Man if it would read my wide bands I get this bad boy.
Old Aug 21, 2010 | 09:19 AM
DavesZ#3's Avatar
DavesZ#3
If you're talking about the OEM wideband O2 sensor, then yes it should read that. If you've added your own, no it won't see that because that doesn't run through the ECU and is not available from OBD.
Old Aug 21, 2010 | 09:50 AM
Z PHAT Z's Avatar
Z PHAT Z
Wondering if you can buy a serial to usb converter and plug this to the Haltech and read from the Haltech?
Old Aug 21, 2010 | 10:04 AM
Gingervitis526's Avatar
Gingervitis526
This is cheap even for a code scanner it seems like(i just did a quick interweb search )
Old Aug 21, 2010 | 10:11 AM
graffkid732's Avatar
graffkid732
I think I may buy it just to read codes. And the "sale" ends tomorrow with the price going back to $200. Not sure how true that is or not.
EDIT: Just ordered mine
Old Aug 21, 2010 | 10:25 AM
0jiggy0's Avatar
0jiggy0
You guys are right. Even for s simple diag tool its stupid cheap. Im buying it for cars I work on.
projectsupra's Avatar
projectsupra
Cheap ELM327 are $20 shipped, if you have an Android (Torque) or iphone the programs are free and do the same things and more including logging and trip location mapping.
TORQUE in my Z is only able to read coolant temp, air temp, individual cam timing, tps, load, rpm, fuel trims, and a few other values from the ECU though, and a component status widget.
PLX bluetooth OBD reader works much better with the programs, but at a cost.
Pfft.. marked down 80% $40 is good though.
Old Aug 21, 2010 | 10:26 AM
2004Black350z's Avatar
2004Black350z
Exhaust Whore
I wonder if it updated daily saying the next day is the last day of the sale?
If so ill order on monday
Old Aug 21, 2010 | 10:30 AM
graffkid732
Just did a quick search on ELM327
I didn't see a screen or anything on it showing codes or how to clear them. Am I missing something?
Old Aug 21, 2010 | 10:43 AM
cdoxp800's Avatar
cdoxp800
Yep I am taking about my OEM widebands on my 06. This will be fantastic.
Just place my order.
Old Aug 21, 2010 | 11:26 AM
DavesZ#3's Avatar
DavesZ#3
Remember, it doesn't read AFR, it only reads the voltage:
•Bank 1 0xygen Sensor 1 Voltage
•Bank 1 0xygen Sensor 2 Voltage
•Bank 1 0xygen Sensor 3 Voltage
•Bank 1 0xygen Sensor 4 Voltage
•Bank 2 0xygen Sensor 1 Voltage
•Bank 2 0xygen Sensor 2 Voltage
•Bank 2 0xygen Sensor 3 Voltage
•Bank 2 0xygen Sensor 4 Voltage
