Oil Pan Spacer!
Old Aug 29, 2010 | 07:07 AM
weiboy718's Avatar
weiboy718
Default Oil Pan Spacer!
Hello, i'm wondering if you guys know where my dip stick level should be at after adding an oil pan spacer. is it suppose to read higher on the dip stick or lower since it's extended. thanks!
Old Aug 29, 2010 | 07:13 AM
str8dum1's Avatar
str8dum1
it should read the exact same bcause you add more oil
Old Aug 29, 2010 | 07:15 AM
DavesZ#3's Avatar
DavesZ#3
The dip stick measures the TOP of the oil surface, not the depth. You'll be adding an extra quart to bring it up to that point.
Old Aug 29, 2010 | 07:18 AM
weiboy718's Avatar
weiboy718
it's reading a bit over the high side. we dumped in 8qts of oil but i also have a oil cooler so i figured some will drain out while we're doing the install. sorry, i forgot to add i have the VQHR37 and our engine might need more oil than usual. my oil pressure currently reading 27-30psi on start up and driving over 3k is 96psi. after warmed up it's about 17-20psi. does that sound right to you?
Old Aug 29, 2010 | 08:58 AM
uglyduc's Avatar
uglyduc
350hr with a spacer and 19row setrab takes 7qt. 8qt might a bit much.
Old Aug 29, 2010 | 10:15 AM
weiboy718's Avatar
weiboy718
Alright, thanks! I just removed a quart of oil.
Old Aug 29, 2010 | 12:57 PM
DavesZ#3's Avatar
DavesZ#3
Those pressures sound normal.
Old Aug 29, 2010 | 01:39 PM
jeffie7's Avatar
jeffie7
Why would you remove/add oil based on anything in this thread? YOU have the dipstick, not us. Add/remove oil until the oil is near the full line.
Oil spacer + oil cooler I'm at just under 8 quarts in my 03 350z.
Old Aug 29, 2010 | 01:43 PM
weiboy718's Avatar
weiboy718
did you even read my first post? i wasn't asking for any help on adding or removing oil.
Old Aug 29, 2010 | 02:20 PM
djamps's Avatar
djamps
It's my understanding you don't want your oil return line(s) from your turbo submerged, at least while it's running. I keep mine filled between the low and middle area if checked right after shutdown. Around 6 quarts to get there.
Old Aug 29, 2010 | 02:33 PM
jeffie7's Avatar
jeffie7
You asked where the oil level should be on the dipstick, someone clearly answered you, "the same level as before" so after someone posted up how much oil he used, you said, thanks! I just removed a quart of oil. At that point I said, don't fill your oil based on what someone else says. You have the dipstick and if you read your own thread I'd know to fill the oil near the top of the dipstick where the F line is.
Old Aug 29, 2010 | 04:57 PM
weiboy718's Avatar
weiboy718
hey man, thanks alot! you're right!
Old Aug 29, 2010 | 04:58 PM
weiboy718's Avatar
weiboy718
i don't have a turbo but thanks for the tip if i ever go TT
Old Aug 29, 2010 | 05:39 PM
ITOzann's Avatar
ITOzann
wei you are gay :P jk..
Old Aug 29, 2010 | 06:17 PM
weiboy718's Avatar
weiboy718
so are you hahahaha! stop picking on a noob already!
Old Aug 29, 2010 | 06:33 PM
jeffie7's Avatar
jeffie7
Wait, did I hear that someone in here has some lotion?
Old Aug 29, 2010 | 06:45 PM
weiboy718's Avatar
weiboy718
pass it on to Itozann, he may need it hahahahaha.
Old Aug 30, 2010 | 11:14 AM
ITOzann's Avatar
ITOzann
Lotion lotion!!! I think u were sticking the dipstick somewhere else wiboy XD... Did u say u found some brownish substance lol
Old Aug 30, 2010 | 11:22 AM
weiboy718's Avatar
weiboy718
Of course i did, it was up your ***
Damn, homos! Hahaha!
Old Aug 30, 2010 | 03:52 PM
uglyduc's Avatar
uglyduc
Yep.. use the suggested value of 7qt as an estimate. Almost positive the 370 and hr350 share the same bottom end, there are a number of variables that can change the actual amount required. Best bet is start reading the dipstick after 5qt, slowly add the 6th, 7th or 8th as required.
7qt with a gtm spacer and 19row setrab ~4' -8an tubing brings me almost to the full line. Confirmed. 4 oil changes now... 28qt of damn oil already.
