Head gasket blown?
Old Sep 23, 2010 | 09:46 PM
- bigc -'s Avatar
- bigc -
http://www.amazon.com/Lisle-24610-Sp.../dp/B001A4EAV0
Old Sep 24, 2010 | 05:23 AM
McLovin350Z's Avatar
McLovin350Z
THANKS!!!!
I'm overheating at cruising hwy speeds and also when im in my boost range (above 3000 rpm) alot for spirited driving
Old Sep 24, 2010 | 07:04 AM
binder's Avatar
binder
Originally Posted by RED RIDER
Can someone tell me exactly WHY it is detrimental to run an engine colder than what it would be with the tstat in..for example my car will only warm to 15-160 in 50 degree weather without a tstat..so WHY is this detrimental?
engines have a good effeciency range. 160* isn't bad but when the engine isn't fully warmed the oil isn't at optimum temps, engine clearances can be different also.
There is more to it, but i'm not an engineer. You aren't going to blow your engine at 160* though.
I always wait til my coolant is at operating temps (180) and oil temps are over 160* before i put any strain on the engine.
Old Sep 25, 2010 | 10:53 AM
RED RIDER's Avatar
RED RIDER
Default HUGE Thanks!
Thanks guys for the info about bleeding the cooling system..specifically Binder...GENIUS! Never realized that about lifting the REAR of the car...bled it three times completely hot to ambient..sealed it off..and just came back from beating the hell out of it....high boost, low boost, etc etc...180 degrees..worked like a charm!!!! THANK YOU!!!
Goes to show that you DO learn something new everyday!.
Old Sep 25, 2010 | 11:40 AM
Sylvan Lake V35's Avatar
Sylvan Lake V35
Originally Posted by McLovin350Z
Can I get a pic of this spill free funnel
Old Sep 25, 2010 | 02:45 PM
binder's Avatar
binder
you're welcome! I'm glad you got it fixed.
like i said, its weird how they have the system setup, to get the air to the radiator the car needs to be lifted in front but that causes air pockets in the heads so it needs to also be lifted in the rear. confusing setup but once you conquer it everything is great.
Old Sep 28, 2010 | 05:44 AM
McLovin350Z
Binder
I wanna be sure I understand ur trick to bleeding
U agree with lifting the front of the car up and bleeding a few times but then you recommend we lower the front and lift the rear and bleed again several tries
Old Sep 28, 2010 | 12:06 PM
RED RIDER's Avatar
RED RIDER
Binder
Worked like a charm...if you have seen the area behind the tstat housing it is clear that air can get trapped in there...back the car up a set of ramps and the water will flow into that pocket and force the air out!
I bled 3 times hot to ambient and it worked great..
burglapfd
Dec 6, 2020 01:04 PM
sales@czp
Sep 23, 2019 03:30 PM
